SUPER SUNDAY SHOOTOUT...Are you ready to Rock?...INFO POSTED
- Rich Maitre
MAY 10th, Maple Grove PA. This is gonna be a show for everyone, this is not just the normal N/A show. Not only will we have 4 classes of the fastest all motor cars in the country but we will have the sick-est power adder show as well with.....The baddest Outlaw 10.5 cars in the northeast, Not to mention the quickest Outlaw Drag Radial cars on this side of the country and a deadly field of 8.50 index racing. Gonedragracing.com will be hosting a killer car show and swap meet, vendors will be displaying their products and who knows what celebrities in the racing world that you may just bump in to.
No matter how far the grove is from you, you wont want to miss this show, so start walking now, hitch a ride, camp out for the next month, bring the wife, the girlfriend or the wife and girlfriend, just make sure you are there. This is the show thats gonna become the Giant Star on your calender every season. This is the day to bring together the entire GDR crowd and help us....MAKE SOME NOISE!!
Rich Maitre, race director
Super Sunday Shootout
http://www.nashootout.com" onclick="window.open(this.href);return false;
Distributor for:DART JESEL Moroso REV Victory1 Manley VP Kestrel
- iceman
- Pimp Status
Pyott Racing
Re: SUPER SUNDAY SHOOTOUT......Are you ready to Rock?
I will be ready(for real this time
) and all my rod bolts will actually be tight
INDUCTION SOLUTIONS
2nd Annual YELLOWBULLET.COM NATIONALS Sept 2,3,4 2011[/b][/color]
Glauner's Auto Body Inc Parkesburg, Pa. (610)593-2775
Hickrocket1258
- Quarter mile
I will be ready and there racing. I will be trying to bring many friends to watch as well.
1985 Z28 Camaro...Just a slow drag radial car.
Work harder....Millions on wealthfare depend on you.
Pyott Racing
any word on when the gates are opening, entry fees,purse etc?
INDUCTION SOLUTIONS
- Rich Maitre
Schedule for Super Sunday Shootout
Run Order:
Purnell Body Shop AMI
RAM Racing Drag Radial
G-Force 10.5
Liberty's Gears PRO N/A
8.50 Index
Outlaw Drag Radial
Outlaw 10.5
Schedule:
8:00 Gates/registration open/Tech (All D/R cars to be Head Teched)
9:45 Racer Meeting
10:00 1st Round Qualifying
11:00 2nd Round Qualifying
11:45 Cookout/Car Show Cruise
12:00 1st Round Elims
1:00 2nd Round Elims
1:30 AMI only
2:00 3rd Round Elims/Car Show Awards
3:00 4th Round Elims
3:30 AMI only
3:45 Finals
4:00 Winners Circle Pics
***All Classes will start and finish together, shorter fields will sit out middle rounds***
Rules for Outlaw 10.5/Outlaw Drag Radial/8.50 Index
Outlaw 10.5
1/4th mile racing, all run field
1. 400 Pro Tree Heads Up Racing
2. Engine:
A. Naturally Aspirated
i. Small Block 2300 lbs
ii. Big Block 2500 lbs
B. Nitrous Oxide:
i. Small Block 2500 lbs
ii. Big Block 4.840 & 4.900 Bore Center 2700
iii. Big Block 5.00 Bore Center 2800
iiii. Big Block 5.20 Bore Center 2900
C. Turbo Charged and Super Charged
i. Single SB 2700 lbs Big Block 2800 (If larger than 4.900 bore spacing add 100 lbs)
ii. Twin Turbo 3050 lbs (If larger than 4.900 bore spacing add 100 lbs)
iii. Centrifugal Supercharges SB 2700 lbs, BB 2800 lbs(If larger than 4.900 bore spcing add 100lbs)
iiii. Roots Supercharger SB 2700 lbs, BB 2800 lbs(If larger than 4.900 bore spacing add 100lbs)
v. Screw superchargers 3050 lbs (If larger than 4.900 bore spacing add 100 lbs)
vi. 4 & 6 cylinder smaller then 250 cid, alcohol & intercooler permitted, base weight 2300 lbs
3. Back Half Type Cars Only, ALL cars must have mufflers - inserts are NOT considered mufflers
Exhaust must exit at least 12" behind rear of front axle centerline.
4. Front Frame to be original O.E.M. type. (stock front frame rails mandatory) Direct bolt in aftermarket
parts permitted. Firewall must be in the stock location. Engine must remain in front of firewall. Firewall
can not be modified for engine placement.
5. Must be Street appearing, must have stock appearing dash and working lights, one piece fiberglass .
front ends permitted. If you use a one piece fiberglass frontend, it must have lights.
6. Alcohol on NON intercooled cars only.
7. NHRA Pro Ladder.
8. Minimum ground clearance of 3" from the front of the nose to 12" behind centerline of the front axle.
9. Towing will be allowed, you must stop at scales, time slips can be picked up at scales.
10. General Rules: deep staging allowed, but track will not wait for a racer to get deep staged. When both
pre-staged are activated, either side stage light will start a 7-second stage count. Failure to activate stage
bulb within 7 seconds will result in disqualification/timeout. (Starter's decision will be final). Disqualification
will be based on a first or worse situation. Rules on controversial situations will be final at the discretion of
the race director.
11. Head & Neck Restraint - MANDATORY
12. Lower engine containment device (Diaper) - MANDATORY
13. Maximum front overhang 45" From centerline of front spindle.
No car will be allowed to go faster than the chassis is certified for by NHRA Race Directors Decisions on all
matters will be FINAL
RACE DIRECTOR HAS ALL FINAL DECISIONS
Drag Radial
1/4th Mile Racing, all run field
1. .400 Pro Tree heads up racing.
2. All NHRA & track safety rules in effect.
3. Factory transmission & converter, OEM stick accepted
4. Base weight 3200 lbs
5. DOT Radial tire - must fit in quarter panel
6. Single type power adders only
7. Stock type front suspension, direct bolt on replacements accepted
8. Stock type rear suspension mandatory
9. Mini Tubs and coil-over's permitted. Must retain stock frame rails, may be notched for tire clearance. Back half cars prohibited, Ladder bars add 100 lbs.
10. NO wheelie Bars
11. Mufflers mandatory
12. Working lights
13. Deduct 400 lbs for Nitrous small blocks
14. Diapers recommended
8.50 Index
1/4 mile racing, All run field up to 32 cars
1. .400 Pro tree heads up with 7 second auto start
2. Minimum weight 2800 lbs
3. Courtesy staging advised (NO deep staging allowed)
4. Full bodied street appearing car only - No roadsters, altered, dragsters
5. Lettering allowed on windows only
6. NO full round or square tube chassis
7. Stock style front suspension (bolt on aftermarket part accepted)
8. Tran brake & two step allowed
9. Throttle stop/controllers, delay boxes/devices PROHIBITED
10. Automatic shifters PROHIBITED
11. Car & Driver must meet NHRA & track safety rules
12. Gasoline only No Nitro or Alcohol
13. Max tire size of 33 x 10.5w
Race Director has all final decisions
Payouts/Entry
8.50
win 1000
ru 350
semi 100
1/4 50
entry 85
O/L Drag Radial
win 1300
ru 500
semi 150
1/4 50
entry 100
O/L 10.5
win 1750
ru 700
semi 200
1/4 50
entry 125
Run Order:
G-Force 10.5
8.50 Index
Outlaw Drag Radial
Outlaw 10.5
Schedule:
9:45 Racer Meeting
1:30 AMI only
3:30 AMI only
3:45 Finals
Outlaw 10.5
2. Engine:
B. Nitrous Oxide:
7. NHRA Pro Ladder.
the race director.
Drag Radial
10. NO wheelie Bars
12. Working lights
8.50 Index
Payouts/Entry
8.50
win 1000
ru 350
semi 100
1/4 50
entry 85
O/L Drag Radial
win 1300
ru 500
semi 150
1/4 50
entry 100
O/L 10.5
win 1750
ru 700
semi 200
1/4 50
entry 125
Pyott Racing
Re: SUPER SUNDAY SHOOTOUT...Are you ready to Rock?...INFO POSTED
Thanks Rich!
INDUCTION SOLUTIONS
BlownchevyII
Looks good Rich!! See you there!
10secBu
- Rich Maitre
Everytime I hear that I get stoked, ready for the season to begin.
Its gonna ROCK!!
Rich
Its gonna ROCK!!
Rich
Red Rocket Outlaw
Hey Rich,So when it says "Head & Neck restraint" You mean a "Hahns device" ? I am talking about the "Outlaw 10.5 class,which you have setup to run 1/8 mile,correct ?
- larrye827
I'll be there Rich, hopefuly Hansen would have my engine ready soon.
- Rich Maitre
All classes will be running 1/4 mile, sorry if posted otherwise.
Rich
Rich
- mrhockey
- 1000ft
Since Rich must have missed your question I will say yes he means a Hans or similar device, Hybrid Rage, etc.Red Rocket Outlaw wrote:Hey Rich,So when it says "Head & Neck restraint" You mean a "Hahns device" ? I am talking about the "Outlaw 10.5 class,which you have setup to run 1/8 mile,correct ?
r boffo58
how much is a swap spot? thanks ron.
- Rich Maitre
General admission $10
Car Show Spot $15
Swap Meet Spot $20
Manufacturer & Vendor Midway...Contact me
Kids under 10 free
Rich Maitre
610-932-0367
Car Show Spot $15
Swap Meet Spot $20
Kids under 10 free
Rich Maitre
610-932-0367
redline
I would like to thank all my sponsors who make this event possible.
Bocellas auto. Thanks Mike.. http://www.boccellasperformance.com/" onclick="window.open(this.href);return false;
Andy jensens engine tech.
http://www.jensensenginetech.com/" onclick="window.open(this.href);return false;
Way cool rod Shop lancaster pa. 717-394-1353
East penn manufacturing(deka batteries)
http://www.eastpenn-deka.com/" onclick="window.open(this.href);return false;
Creamery tires thanks Rich.
http://www.creamerytire.com/directions.htm" onclick="window.open(this.href);return false;
Rubright racing ent.
267-226-0837
PSI motorsports thanks frank.
http://www.psimotorsportsinc.com/" onclick="window.open(this.href);return false;
Hopefully more to be added later and higher payouts. Any sponsorship inquirys call Shawn at 610-929-4790 Thankyou.
267-226-0837
Joe Grippo
A few questions...
Sorry if I missed it somewhere, but how much to run AMI? Are there any additional fees for the track or to join the series?
And will the one race waiver be in effect for cars with no mufflers?
I am thinking I will be in C/AMI....Looking forward to it!
Wanna see some pictures?
http://public.fotki.com/JoeGrippo/ &
http://www.flickr.com/photos/joe_grippo/sets/
WWW.NASHOOTOUT.COM
[quote="Joe Grippo"]
A few questions...
How much to run AMI? $50
Are there any additional fees for the track or to join the series? Tech card is $35 or $40 and nothing to join the series.
And will the one race waiver be in effect for cars with no mufflers? Yes!
Hope to see you at the Grove!
KING
A few questions...
KING
www.nashootout.com
ALL MOTOR DRAG RACING!
Joe Grippo
Cool. Thanks for the quick response. See you there....
