It is currently Sat Jan 19, 2019 2:21 am
Post new topic Reply to topic  [ 5 posts ]
 Post subject: Oil squarting from engine block SBC 350
PostPosted: Sat Apr 03, 2010 2:26 pm
I was running my SBC 350 and noticed oil spraying out from the hole at the bottom of the engine.Anyone else have this problem?Pic below shows what hole is spraying oil.When i press the gas it sprays
Posted: Sat Apr 03, 2010 2:58 pm
 Post subject: Re: Oil squarting from engine block SBC 350
PostPosted: Sat Apr 03, 2010 2:58 pm
Just put a SHORT bolt in it to plug it. The fuel pump pushrod is behind it. If your not running a mech. fuel pump you can put anything in it.
PostPosted: Sat Apr 03, 2010 4:16 pm
Thanks I put a really short bolt in there with thread sealant,then the fuel pump went bad :\
PostPosted: Sat Apr 03, 2010 6:48 pm
if the bolt is 2 long it will bind the fuel pump rod against the block
PostPosted: Sat Apr 03, 2010 8:52 pm
Well i took the old fuel pump off and i moved the rod up and down with my fingers so its fine,put a new pump in and it works great.
Users browsing this forum: No registered users and 12 guests
