1966 Ford Fairlane 500 Question
boldandwise2
Post by boldandwise2 »
I was wondering what else could cause my reverse lights not to work?I've replaced the bulbs and checked the fuses,but still does not work all other lights work maybe a ground.1966 Ford Fairlane 500.
Espresso
Re: 1966 Ford Fairlane 500 Question
Post by Espresso »
Sorry for a late response. I don't get around to these sites much.
If you have not figured it out, it is more than likely your back up(reverse) switch.
Give a call to these guys & they should be able to hook you up.
http://www.perogie.com/index.html
-Tom
fairlaniac
Post by fairlaniac »
I only checked this section today for the first time. Hope you figured out your problem. Could it have been your everse switch at the shifter? They start to fall apart at this age.
Tell me more about your Fairlane, I have a '66 390/4 speed.
Doug Bender
1966 Fairlane 390FE/4Spd
