12 bolt chevy for GM A-Body, from a 68-72 Chevelle, but will fit 64-67 with different backspace wheels. Will also fit in a G-Body.
-Welded and Pinned axle tubes
- Strange Spool 4 series
- Richmond 3.73:1 ring and pinion
- Aftermarket axles, induction hardened from Alloy USA
- Strange C-Clip eliminators
- Solid pinion spacer
- Strange 1350 yoke
- Drum Brakes, new 13/16 wheel cylinders, Aluminum drums and 4 primary shoes.
- Aluminum Support Girdle
Set up, ready to go. Still in the running car. Has been 8.640@ 156.8 mph
$1,250.
I can also swap in a used 4 series posi and/or a set of Richmond 4.30 gears at that same price.
12 bolt Chevy, A-body
bowstang
Re: 12 bolt Chevy, A-body
interested in rear if still available.please call 610-459-9477 steve
