Any tips for a newbie
lightemup
- Forum Moderator
Im going to try my hand at organized racing for the first time this year in the 12.0 class any tips you veterans can give me? Ive been down the track about 30 times just never really been concerned with reaction times except armdrops on the street.
4doorbu
Re: Any tips for a newbie
practice and get realllll good at a pro .500 tree, and have your car ready to run 11.90's and learn when to hit the brakes!
and is this andy from mullica hill?
lightemup
- Forum Moderator
SuperSport
Litemup,
Good advice already in the above post for ya......get the car to run 11.90 and 'wheel race' your opponet. Lots of games are played at the stripe
lots of things you can do to adjust your reaction time and ET on the starting line. Shallow staging, rolling in deeper.......even deep staging (turning off the top bulb BUT MAKE SURE THE TRACK ALLOWS YOU TO DO SO before you do it or you will likely get DQ'd.....)...rolling in deeper will quicken the reaction, slow the ET (we are talking 2-3 hundredths here).
Also experiemnting with different size front tires will make a difference in reaction time. Small tires= quicker reaction, larger the tire the slower the reaction time (bigger tires stay in the beams longer).
lots more to it than this, but it will get ya thinking. Try lots of stuff at the test and tunes to get it all figured out-
" Dream as if you will live forever, live as if you'll die today" James Dean
- jays64II
my best advice is to set up the car to go 11.90 and then back it down a lil and enter the street bracket class at Atco on saturdays. That is the best practice you will get and the bracket gang will give you all the help and advice you can absorb. great buncha people and many of them run 12.00 anyway.
lightemup
- Forum Moderator
1meandemon
The best advice i can give you is : Make your car go a 11.97 to 12.03 on the first time shot .Next add or subtract weight in your car ,so if i go 11.98 i'll add 30 pounds , so then next pass i sould go 12.01. as the rounds start i will remove weight to each round and air get better. this class is the toughest index class there is .next step you better cut a light, between a .010 to a .030 . I hope this help you ..... The 3 top guys last year are walt hass, jim harvey, jeff mazzoni . if you have a chance watch these guys run. you will learn alot . and watch out for the that female racer barbra lutz. good luck.
- jays64II
There ya go Jeff ! I spiced up your profile a bit !
cam68
That's good advice jeff, sounds like what you told me last year.(thanks for the help w the truck it seems much better) good luck!!!
unk
Jeff , I want to thank you for the advice also, Im sure i can use it.. lol
Give me a call jeff
unk
Give me a call jeff
unk
1meandemon
This 12.00 class is the toughest index class there is .treat every round like the final. how many of you's are really trying, do you take it for granted that your going to beat the other racer. If so your going to lose.Tip part 2: If you leave the line and look over, is the other racer in front or behind you. If the racer is behind you , it usaully means the other racer had a shitty light .so at the top end ( before the finish line )put your front tire in front of the racecar tire ( about a foot ). don't get 2 car lengh in front your going to break out .so back off . you will learn this over time .
P.S. unk you inproved very well last year. keep it going. and to jim harvey that never won a race in his life ,an finished 2 place over all. GREAT JOB
If you are going to win against me you earned it ,I'm not giving and freebee's
cam68
If this year is anything like last year it should be a great time.
Unk,you did great last year!! maybe jeff and i can cash in on
some of that #1 qualifier cash.(if walt doesn't show)
Thanks jeff, you guys helped me out a lot.
unk
Win loose or draw, its all fun. I have alot of fun with all the index guys and girls.
unk
unk
lightemup
- Forum Moderator
unk
Lightemup, Im not much on giving tips on 12.0, cause i have not won one yet. BUT, what i can tell ya, is that you need to cut a real good (light), and get your car to hit that 12.00.1.these guys are brutel. But we do have fun, like i said, and you could not ask for a better bunch of guys & barbara. lol
Hope this helps ya, and good luck
unk
unk
unk
Just try to line up next to the primered black 4 door chevelle with all the rot holes. He's easy pickin's.
- noricehere
- Quarter mile
unk wrote:Looks like that guy from gdr, was on here today.lol
thanks
unk
You've been hooked up Unk
RIP goDragRacing.com 1998 - 2008
www.goDragRacing.org / WTF Web and Graphic Design
Proud Supporter of GoneDragRacing.com
Web Friend bbphotondesign.com
1meandemon
hey unk . you ready to go down and pratice. I need some help, so how about it .
unk
What the hell do you need help with??? lol, Im just a easy target for you professional guys. lol, But i do make you guys think a bit, when your up against me. lol
unk
unk
