In the 9's
Please be kind and link when possible...
1320racer
In the 9's
Post by 1320racer »
1st pass off the trailer Saturday @ 3:11pm with a 1377' DA, DEEP staged and restricted to ~ a 1.50" throttle bore...
60'......1.376
330'....4.059
1/8.....6.322 @ 108.07
1000...8.280
1/4.....9.94 @ 134.77
http://s248.photobucket.com/albums/gg18 ... bigley.flv
Thanks to Mike aka 70 El Camino for the video. 8-)
Now for those not understanding the DEEP staged thing and how it effects ET's, subtract .09 off all those incrementals and that's what it would have run shallow staged!
FYI, without question, unrestricted and shallow staged it would have run at least a low 9.60 today and probably a 1.27 60 foot as delivered/dyno tuned and on dino oil!
Best past to date w/restrictor plate
1.17 60 foot front tires/1.30 back tires(footbrake)
5.54 @ 122
8.77 @ 152
3124 lb. '02 Firebird
http://www.youtube.com/watch?v=rbKYio6OvKM
THE PROOF IS IN THE PERFORMANCE
1.28 60 foot
9.89 @ 134.93 n/a
6.26 @ 109.40
3870 lbs.
miclau
Re: In the 9's
Post by miclau »
congrats, that is awsome keep up the hard work and good luck this season
Thanks To My Sponsors
HAGAMAN RACE ENGINES
schreibs
Re: In the 9's
Post by schreibs »
leaves nice! congrats
306CI/CANFIELDS/TREMEC TKO
Re: In the 9's
what is your throttle bore restriction to et reduction ratio!????? got a handle on it yet?? 9.94 at 134 is close wouls a 1/16 have got it?
1320racer
Re: In the 9's
Post by 1320racer »
The restrictor I'm using is a 4 hole spacer in which the bores are adjustable from 1.750 down to 1.00.
Reducing from the fully open/1.750 bores produce an eliptical shaped bore(s)
As of now, 2 turns = .05 in ET and the adjustments are linear up to 13 turns.
That said, ran 9.89 @ 134.93/6.26 @ 109.40 deep staged off the trailer Saturday 8-) with a 2600+ DA and the worst barometer I've ever recorded at Island 28.98! :shock:
That's .05 quicker in 1300'+ worse air with the same restriction as the week before, when everybody in Pro was running .18-.20 slower. :o
Sill as delievered and dyno tuned by Sunset Racecraft! :D
9.40's are all but guaranteed, shallow staged, unrestricted and in good air.
5.54 @ 122
8.77 @ 152
1.28 60 foot
9.89 @ 134.93 n/a
6.26 @ 109.40
3870 lbs.
