"Feeler AD" 91 Notch For Sale
Vsix
Post by Vsix »
putting this out to the local guys my 91 Mustang Notchback its available turnkey or rolling body here are some details ......
91 Notch Titanium silver factory 5.0 car Nevada car NO RUST garage kept 2.5" Cervinis cowl hood
Interior- gray super clean many new parts w/full Autometer guages B&M Pro-Stick shifter nice CD headunit ect.....
Engine -complete GT-40 302 less than 500 miles TFS stage 1 cam RR rockers head studs GT-40 upper & lower w/spacer 24lb inj Moroso 7qt pan MS balancer MAC UD pulleys Alum edlebrock water pump BBK 70 mm TB Kirban billet reg MS 4 core rad w/electric fan BBK cold air kit ect....
Trans- Comp C-4 T-brake manual vavle body 9.5" 3500 stall convertor w/ballon plate set up for spray good for 800HP braided lines w/big cooler
Rear- factory 8.8 Posi rear MS 3.73 gears Alum TA girdle rear cover ext studs UPR upper & lower conrol arms QA1 adj rear shocks w/Eibach drag springs & air bag MS Alum driveshaft
Fuel- BBK 255 intank pump
Power Adder - Complete Nitrous Express wet kit Shark nozzle adj from 75-150HP w/10lb bottle
Trunk mount battery Steeda kit w/cut off switch
Exhaust-MAC 2.5" cat back w/SS tailpipes
Susp- UMI full length subframe connectors DS loop BBK K-member brace UPR full tubular K-member w/lower arms coil over conversion w/175lb front Drag springs w/Lakewood 90/10s UPR billet caster/camber plates SS manual rack w/SS steering shaft
Wheels & tires- Weld Draglites 15x3.5" fronts w/new 165r15s rears are 15x8 w/5.5" BS w/new Nitto 275-60-15s
Plus so much more i'm forgetting i have well over $12,000 in this car ALL parts are NEW or like NEW condition no exspense spared NO JUNK
Sorry no pics PLEASE call me if you're SERIOUS and local to check it out Rolling or Running
Thanks Jim
215-669-1696
02 GMC 2500HD
81 SBC Malibu
72 BBC Chevelle
Vsix
Re: "Feeler AD" 91 Notch For Sale
Post by Vsix »
It also has a MSD 6AL box... NEW brakes crossdrilled & slotted rotors on front and NEW rear brakes & powdercoated drums ...Clean PA title and PA inspection 8-)
Thanks Jim
215-669-1696
02 GMC 2500HD
81 SBC Malibu
72 BBC Chevelle
Tim1970
Post by Tim1970 »
SOLD!! :o :o :o
