PUMP GAS LIMIT
All you bottle babies post here!
moody34
PUMP GAS LIMIT
Post by moody34 »
In your guys opinion, whats the biggest shot you would safely spray a fogger with pumpgas without detonation? Motor is a 9:1 BBC with autolite 3924 plugs and aluminum heads. thanks, Brian
"...oh god, did you eat all this acid? You better pray to god there's some thorazine in that bag or you're in bad f+*%ing trouble!"
Re: PUMP GAS LIMIT
THAT WOULD DEPEND ON CAM,GEAR AND CONVERTER !!! IF YOUR STREET GEARED AND CONVERTER IS WAY TIGHT THAN YOU CAN WITH THE RIGHT TUNE PUNCH 300 SHOT . IT IS ALL ABOUT PISTON SPEED AND DWELL AND CAM TIMMING .DO YOU HAVE THE RIGHT FUEL TO BURN ANT THOSE LIMITS . HAVE DONE IT WITH A SHORT ROD 377 SBC AND NOS CAM AND HEADS BUT IT WAS DESIGNED TO DO IT .(PUMP GAS WARS)
moody34
Re: PUMP GAS LIMIT
Post by moody34 »
herbert solid cam http://www.dougherbert.com/solidcamlifters-p-9756.html, t400 4000 stall w/3.73 and 27 in. tall tires. hope that clears up a little. thanks for the help, Brian
K*A*B
Re: PUMP GAS LIMIT
Post by K*A*B »
alot ;)
BIRDMAN
Re: PUMP GAS LIMIT
Post by BIRDMAN »
FORGED PISTONS. I know people at the track have sprayed otherwise, saw a kid with a white stang last yr telling me he had 100 passes on hypereutectic pistons god bless him then... Forged Pistons or your liable to get into some trouble. nitrous pistons/gas ported always a plus.
souped up tomato can
Re: PUMP GAS LIMIT
DONT EVER PUT A HYPER -U-CRAPTIC PISTON INTO A DETONATION PRONE SITCH. THEY DONT TAKE IT WELL AND ITS PROTEST WILL BE YOUR MOTOR AT MIN. ..... GOOD SOUND ADVICE .. A STOCK SOFT ALOY CAST WILL LAST LONGER .
