Fuel line /power wire questions?
s10aromeo
Post by s10aromeo »
When running my power wire from the battery and fuel lines down to the front of the truck by the frame rail makes me think.If something happens is it a good idea to have a power wire close to a fuel line if they both were torn.Should I run the power wire on one side and the fuel line on the other frame rail?
OLDHEAD
Re: Fuel line /power wire questions?
Post by OLDHEAD »
When I ran the fuel line and the battery cable I was thinking thing,but which one is safe on the outside...Neither right,so I ran both on the inside of the frame....OLDHEAD
10secBu
Post by 10secBu »
All power lines run inside the car down the passenger side, all fuel lines under the car.
OLDHEAD
Post by OLDHEAD »
10secBu wrote:All power lines run inside the car down the passenger side, all fuel lines under the car.
I don't believe it that what I did,I must be getting forgetful..............oLDHEAD
1990Lx
Post by 1990Lx »
I find no reason not to run you fuel and power wire down the same frame rail. As added precaution i would wrap your wire in plastic tubing (conuveled) and secure both to the frame rail with rubber insulated clamps. and make sure to keep it away from moving parts/heat and other hazzards.
It runs on hopes and dreams but its getting there
