1986 Chevrolet Monte Carlo SS
montekeel
Post by montekeel »
ok so here goes:
1986 monte carlo ss
just under 60,000 original miles
the car has a near perfect interior, ttops with the gm bags, rally sport wheels with almost new tires, true dual exhaust 2.5 inch all the way back into 3 inch tips, tune ups and oil changes were done every 3,000 miles, aftermarket panasonic head unit infinity front speakers, and pioneer rears. the car has a shift kit and a torque converter somwhere around a 2500 stall.
the car is going to need a new right front fender which is a 110 dollars and the passenger door needs to be straightened out then it needs to be painted
For $5,000 you get the car as is also you get a chevy 350 2 bolt block, stripped down almost to a bare block, a 510 lift cam, edlebrock intake, hooker headers, the gaskets, stock heads crank, internals, and oil pan come with the motor, a set of control arm bushings, 8 ac delco spark plugs
I will sell just the car without the extra parts for $4,500
the car is worth about 8 or 9 grand if you fix the minor body work and the value just keeps going up.
let me know if you want pictures or if you wanna come see it
Here's my number 856-308-2682 thanks guys
