69 rebuilt Chevelle for sale
wcs69rat
Post by wcs69rat »
Car resides in orlando, Fl, USA. It is a 1969 CHEVELLE 496 BIG BLOCK. FULL FRAME OFF REBUILD JUST FINISHED. FRAME, ALL SUSPENSION PARTS, REAR END, RADIATOR CORE SUPPORT, AND MUCH MORE ARE POWDER COATED. 454 BLOCK, .060 OVER, MILODON SPLAYED CENTER CAPS, TRICKFLOW 4.250 FORGED CRANK, MANLEY H BEAM FORGED RODS, ARIAS 11.0:1 FORGED PISTONS, CHILDS & ALBERT GAPLESS RINGS, BRODIX BB1 PORTED OVAL PORT HEADS, TEAM G FULLY PORTED INTAKE, GEAR DRIVE,COMP CAMS "ULTIMATE PRO STREET" CAM AND VALVETRAIN, STUD GIRDLE, BLP CUSTOM BUILT DOMINATOR(3 CIRCUIT) WITH FRONT POWER VALVE(TO ENHANCE STREET DRIVABILITY) (FLOWS 1340 CFM), MSD BILLET DISTRIBUTOR, MSD 6AL, MSD TIMING COMPUTER, MSD 2 STEP, GRIFFIN DUAL CORE ALUMINUM RADIATOR.(MOTOR HAS NOT BEEN DYNO TESTED BUT MACHINE SHOP TOLD ME IT SHOULD MAKE APPROX 650 BHP.) TURBO 400 TRANS WITH HIPSTER BRAKE/ REVERSE VALVE BODY, EXPLOSION SHIELD, ULTRA BELL, GEAR VENDORS OVERDRIVE, MORRISON FORD 9" WELDED REAR END HOUSING, STRANGE LOCKER W/ 4.30 GEARS( GVO KNOCKS FINAL RATIO TO APPROX. 3.30) STRANGE 35 SPLINE AXLES, WILDWOOD 4 WHEEL DISK BRAKES, HOTCHKIS CONTOL ARM BRACKET BRACES, MORRISON/GAZAN TUBULAR REAR CONTROL ARMS WITH ADJUSTABLE UPPER ROD ENDS, COMPETITION ENGINEERING 90/10 SHOCKS, MOROSO TRICK SPRINGS. CUSTOM ALUMINUM DASH WITH ALL AUTOMETER GAUGES(INCLUDING SPEEDO AND TACH, SHIFT LIGHTS, ETC), 6 POINT CAGE, RACING SEATS, RACING HARNESSES, MEGASHIFTER, GRANT STEERING WHEEL, IDIDIT TILT COLUMN, FLAMING RIVER VEGA STYLE LIGHT WEIGHT STEERING BOX, NEW CARPET, HEADLINER, DOOR PANELS, SAIL PANELS, NEW WINDSHIELD & REAR GLASS. SHAVED DRIP RAIL AND DOOR HANDLES, KEYLESS ENTRY, SMOOTHED FIREWALL, BODY WAS COMPLETELY STRIPPED AND THEN SPRAYED WITH ETCHING PRIMER BEFORE HAVING BODY AND PAINT WORK DONE. GLASS COWL HOOD, NEW GM FRONT FENDERS, NEW GRILL, NEW BODY MOUNTS(URETHANE). CAR IS BEAUTIFUL BUT THE PAINT HAS SOME FLAWS. THERE WERE SOME ASSEMBLY SCRATCHES THAT I HAD THE PAINT SHOP TOUCH UP WITH A BRUSH. THERE ARE ALSO SOME CLEAR COAT RUNS BELOW THE ROCKER PANELS(YOU PRETTY MUCH HAVE TO BE AT GROUND LEVEL TO SEE THEM). PAINT JOB LOOKS PRETTY GOOD BUT I WOULD NOT CONSIDER IT SHOW QUALITY. THERE ARE SOME FLAWS AND IT WAS PAINTED ABOUT 7 YEARS AGO WHEN I STARTED WORKING ON THE CAR. I HAVE OVER 45,000 IN RECEIPTS NOT COUNTING THE HUNDREDS OF HOURS OF FABRICATION, ASSEMBLY, ETC. FEEL FREE TO E-MAIL ME WITH ANY QUESTIONS (wcs69rat@hotmail.com). THE CAR HAS TOO MUCH TO LIST, BUT I TRIED TO TOUCH ON THE MAJOR POINTS. AT TIME OF ADD, CAR HAD 38 MILES ON IT SINCE REBUILD WAS FINISHED. BUYER IS RESPONSIBLE FOR ALL SHIPPING CHARGES. Price is $38,900 US.
