Relay Wiring
- moody34
Relay Wiring
I'm using a window switch that uses a ground in the rpm window to activate a nitrous relay. Has anybody activated nitrous by keeping the power lead to the relay on and the ground open? pros and cons? thanks for your help, Brian
"...oh god, did you eat all this acid? You better pray to god there's some thorazine in that bag or you're in bad f+*%ing trouble!"
Re: Relay Wiring
you need to use the ground to trigger the relay through the w/o switch . then you can feed it volts through the relay to selnoids. and use the 2 possitives for master and arm
- moody34
Re: Relay Wiring
So arming the Window switch with the WOT switch is no good?
You think arming the WOT switch (with the ground) with the window activated from the master is a better way? thanks for the help
