to anyone that is using one of these plates or has knowledge of them: Im assuming you have to run a carb spacer so the linkage of the carb doesnt hit? I tried to mount it under the nitrous plate and it still hits like that too, so im assuming your running a spacer.
just looking for input
Anyone using Nitrous Pro-Flow's solenoid mount bracket?
BigRedMachine
1968 Chevelle
1985 Mazda RX7-Under construction-SBC swap
2001 Pontiac Trans Am WS6
2001 Chevy Tahoe Z71
1982 Chevy K10 on 44" Groundhawgs
lownslow1988
Re: Anyone using Nitrous Pro-Flow's solenoid mount bracket?
i just put a edelbrock solenoid mount on mine under the plate and it clears all the linkages on my HP 750 DP....post up a link or pic of the one your using
BigRedMachine
http://www.wilsonmanifolds.com/shop/index.php?l=product_detail&p=58
I have the one that hoods 2 solenoids
1968 Chevelle
James Ratliff
Even though I haven't use one, the edelbrock ones look about the same for half the prince in Jeg's.
I am thinking of using the aluminum ones where it has the throttle cable bracket on it as well and the other side is just the solenoid. I will attempt to attact a pic.
Edelbrock one http://www.jegs.com/i/Edelbrock/350/72287/10002/-1
Ones I like http://www.jegs.com/i/JEGS/555/15125/10002/-1 and http://www.jegs.com/i/JEGS/555/15130/10002/-1
Good luck
James
Good luck
James
Pyott Racing
do you have room to mount the solenoids on under side of the bracket?
INDUCTION SOLUTIONS
2nd Annual YELLOWBULLET.COM NATIONALS Sept 2,3,4 2011[/b][/color]
Glauner's Auto Body Inc Parkesburg, Pa. (610)593-2775
Vajunhura
Site section, then felt like it and use it a lot.
