carb linkage
91vert
carb linkage
hey guys i have a 302 with a 750 DP i had a no name throttle linkage so i decided to change it to a jegs throttle linkage with a return spring. now the throttlr linkage bracket comes back father than the other. i need to find a long throttle cable and would like to know where i could find one
Re: carb linkage
go to lokar!!!!
91vert
Re: carb linkage
now would that bolt right up to the bracket or would i ahve to make some mods to make it work. im trying to get it done this week bc im tryin to go to ford vs buick at acto
91vert
Re: carb linkage
also wat part number would that be?
- d2racer
- Quarter mile
Re: carb linkage
? what bracket did you buy ? if you bought the one for ford linkage the lokar cable will not bolt on without machining the bracket .
but whats the issue? all the jegs brackets feature an adjustable mounting block , i have one on my car , i switched to a carb cable when i switched out the efi , not truly nessasary but neater , bolted it the adjustment block and carb , adj it to take out the free play and lock it down , possibly you have an old style carb with the attachment point way to far forward and up? you may have to find another hole to mount the linkage rod to or drill one . the throttle cable or bracket should not be an issue. they are all pretty much identical
"your only as good as your last round!"
