Will a ford 8.8 hold up to a 10.00 nitrous pass and last???
Transmission & Driveline - Auto, manual, clutch, convertor, driveshaft, rear, axles, etc...
BLOCKHEAD75
Post by BLOCKHEAD75 »
Thinking about building a 10.00 S-10 next season
and putting a explorer 8.8 rear in it to save some cash
will it hold up if i beef it up a little??
vino350
Re: Will a ford 8.8 hold up to a 10.00 nitrous pass and last???
Post by vino350 »
ford 8.8s can go into the 7's on drag radials. ull be fine :hay:
85 s-10
J@E Performance
that is a great fit!!! the weak link is the mounting in a fox body and the tubes bend!!!!
if your going big get the pinion support cover and a axle tube brace . there was a great article in FSC on that swap. ALWAYS cheak that the tubes are straight!!! ya dont want to spend the bucks and then need another doner !!!
vino350
Post by vino350 »
85 s-10
J@E Performance
