burnout and ran the engine up to 6500 rpms. My oil filter exploded! I used the exact same oil (royal purple 20W 50) and filter (fram ph16) as I always use. Oil pressure seemed about normal as I started the engine and warmed it up (75psi or so at idle and 125 or so when revving the engine). As soon as I heard the pop I shut the engine off and put out the small fire. I got it home and cleaned it up and replaced the filter and topped off the oil. Thankfully the engine seems fine. This motor is 2 years old has over 200 1/8th mile passes on it. What do you think happened? The motor is a 390 ci small block mopar with a high volume melling oil pump and a milodon 7qt pan. Again this is the same filter and oil I have used for the last 2 years.Thanks,
Mike
