difference in converter stall speed?
big ken sloat
i have a 434 sb with around 585hp and about the same torque. cam is 600 lift, with a ati treemaster 4500 stall. im going to a 468 around 700 hp and would asume around 600+ torque. cam is 680 lift, how do you think using the same converter will act since the torque is about the same? thanks ken ps i did get a treemaster converter with motor around 5300 but i thought it might be too much for street.
mike
- Pimp Status
Re: difference in converter stall speed?
big ken sloat wrote:i have a 434 sb with around 585hp and about the same torque. cam is 600 lift, with a ati treemaster 4500 stall. im going to a 468 around 700 hp and would asume around 600+ torque. cam is 680 lift, how do you think using the same converter will act since the torque is about the same? thanks ken ps i did get a treemaster converter with motor around 5300 but i thought it might be too much for street.
The current stall convertor your running, how close to 4500 does it stall with the current motor?
BBC on spray...
KOP prove me wrong
KOP prove me wrong
big ken sloat
i just went with the 48 to 51 stall since it was matched to this motor
your gonna want to get that tightened up for the street and nos use..........
i have seen 500 rpms from 3.45 to 3.75 stroke in same engine head cam combo
