Caster/Camber install help need
Suspension related items
NsTyFoX
Post by NsTyFoX »
The cast/camber set are maximum motorsports and I actually need help getting my pas side strut off.. I was able to install the driver side fine but on the pas side I can't get the top nut off the strut. I put a small wrench on the strut and the proper size wrench for the strut nut and the damn strut and all spin instead of the nut breaking loose. Anybody have any ideas on how the hell to get this damn strut nut off? the strut if it matters is lakewood and this is on a 91 mustang.
Thanks
Jim
91 gt-some mods
Re: Caster/Camber install help need
Ahh what a pain in the ass, I've had those things stick on me. Are you saving the struts or replacing them?? If you are replacing them then I would just find something to grab on to that strut shaft and hold it still while you get the nut off. If you have to save them then you can't do that, it will nick up the shaft. I used to hit it with a ton of PB blast, come back in an hour or so, get a deep offset wrench to hold the nut then use another to grab the shaft and just muscle it loose
NsTyFoX
Post by NsTyFoX »
yea im saving my lakewood struts,i cant beleive this damn thing :mad2: ,the drivers was cake,but the damn rubber bump stop is killing me on the passenger side.
91 gt-some mods
Man I hear you, I am always cursing at those things.
NsTyFoX
Post by NsTyFoX »
i got it, i started out cursing at it(which helped) and then took a grinder to the nut and cut the bitch apart. I was able to save my strut to :cheers:
91 gt-some mods
nice that works :)
rednotch
Post by rednotch »
NsTyFoX wrote:i got it, i started out cursing at it(which helped) and then took a grinder to the nut and cut the bitch apart. I was able to save my strut to :cheers:
god damn invest in an air compressor and a GOOD impact gun
you hit it with a impact gun tap tap tap tap and it did not budge ??thats a new one .my spring compressor is on the wall offsets so i can get my gun on top
