Rear end is not centered.How do i fix it?
Transmission & Driveline - Auto, manual, clutch, convertor, driveshaft, rear, axles, etc...
Frylok
Post by Frylok »
The rear is not centered.I put new tires on it today and one tire is in the wheel weld all the way and the other tire sticks out an inch or 2.I jacked it up and look straight back at the drive shaft and its not straight.I got a 71 nova with leaf springs.Is there any way to fix this?
d2racer
Quarter mile
Re: Rear end is not centered.How do i fix it?
Post by d2racer »
depends on whats wrong , not sure about novas but mopar are purposely off center but sounds like something bent in your car if the driveshafts not straight
first off have someone follow you to see if the car is tracking straight
unibody cars can get bent over time from beating , roll bars and frame connecters are wonderfull if you intend to keep it long term
then you have to find where the trouble is , bent shackles ? warped or bent main leaf , maybe just worn sloppy bushings?
if you have ladder bars are they bent or binding ?
process of elimination
"your only as good as your last round!"
SmallBlockNova
Post by SmallBlockNova »
Broken centering pin(s)? Rear off the pins? Multi leaf or mono?
Just another streeter
Frylok
Post by Frylok »
SmallBlockNova wrote:Broken centering pin(s)? Rear off the pins? Multi leaf or mono?
Mono springs.also its a 4 door nova.Dont know if their longer than the 2 doors?
Frylok
Post by Frylok »
Well i tried to unbolt the rear and shift it over but theres a bracket welded on the tube and a bracket welded on the leaf so im think it might be the leafs that are bent.The passenger side quater panel and door are a different green then the rest of the car.Maybe the car was hit or somthing and the subframe is bent? Could that be? It doesnt look like the quater was replaced it looks all stock and unwelded
