What is needed out side of a drive shaft safety loop and a roll bar at 11.49?
Id rather install this stuff before getting kicked out and im rounding the corner quickly now.
11.49
mightymouse0355
11.49
R&M Mobile Automotive serving NJ, DE, PA (Foreign, Domestic, and Performance)
slimbo5
Re: 11.49
jacket,belts,loop and i think thats it. besides the obvious . battery hold down,carb return springs, lugs and studs (depending on wheels). i have a question for you since i know you run n2o. if the bottle is in the trunk does it still have to be vented to the outside?
mightymouse0355
Re: 11.49
Thats a good question. Mine isnt and they have never said anything to me so im guessing not. The techs know its back there no I would think they would have said something about it by now if I was suppose to have it ventedslimbo5 wrote:since i know you run n2o. if the bottle is in the trunk does it still have to be vented to the outside?
- dscorlett
Re: 11.49
This is from the rule book,
10.6 Head Protector: In any car with roll bar or roll cage a padded head protector must be provided at the rear of the driver's head. Also required if car 135 MPH or faster.
So the roll cage must have padding near the drivers head.
My friend was running between 10.20 and 9.80 and we just vented the tank vent thru the trunk. He does have a fuel cell though.
1996 Z28 Vert. M6
355 Wiseco forged pistons, GM hotcam, GM 1.6 Rockers, Polished and blended LT4 heads & Airgap intake port matched, 52mm TB, 30lb injectors, NGK TR5's, F-body Elbow and Moroso CAI, "Be Cool" radiator, 195* stat, Meziere electric water pump, 6qt pan with high volume pump, Pacestter long tubes and y-pipe, and Magnaflow catback. PCMforLess tune. Do I need to say more??
