Driveline Angle
Posted: Mon May 25, 2009 11:20 am
I was reading an earlier post and thought I'd try to get clarification....
Should the trans output shaft and the pinion shaft be in line (flat or zero degrees) when rear is loaded (loaded on jackstands that is as opposed to under acceleration).
