SBC 406 - 400 bored 30 , new cam brgs , freeze plugs. std std polished crank, keith black signature pistons, h p oil pump , 2 bolt mains, new 530/530 solid lift cam & lifters, new timing chain. chrome oil pan, new rings & bearings, fresh # 186 heads, 202 & 160 stainless valves, new 1.447 double valve springs & retainers. New scorpion roller 1.6 rockers. New longer push rods , heads have studs & guide plates, and powder coated RPM intake. Motor has just been freshened up. $1700
11.1 VORTEC 350 SHORT BLOCK -86-up 350 block bored .030 with 11.1 sealed power forged pistons.This is a Canadian made high nickel 1 piece rear main seal Vortec block.It has a new GM crank and reconditioned x rods with 200,000 psi ARP rod bolts.It also has 4 bolt billet steel main caps.Motor should be good for at least a 500 hp base build up.An electric fuel pump will be needed for this block.Fuel pump boss is not drilled for a mechanical fuel pump.Fresh from machine shop.$1800
350 VORTEC LONG BLOCK -motor built by Prototype Performance in Wilmington De.Complete from carb to oil pan and fly wheel to water pump.It has a mild GM Performance roller cam and the good 906 casting heads.The motor did not need to be bored therefore it is standard bore.It includes a new 600 cfm Holley carb and should be right around 300 horse.The only things you don't get with this motor is a distributor and starter.Pictures available,just send me your email if interested.$2000.00
400 sbc oil pan,balancer and flex plate in very good condition from a 48,000 original mile motor. Decided to go with a 7qt oil pan and an sfi approved balancer and flex plate for my rebuild. $65 for all +shipping.
JDM Universal Racing Seats - Black in color, reclining seats with sliding seat tracks. New Paid $299. Seats are in perfect condition.
$200 Pick Up Only.
600 holley double pumper with new 6an steel braided line.Its been on the shelf for about 6 months in a box.
$225 + shipping
Disc Brake Rear - I have a 79 trans am disc brake posi rear with 4.10 gears.It has new brake pads,new calipers and new brake lines oem style.Bolt in ready to go.You can pick this up at my house or can arrange to meet within a reasonable distance.$600 pick up only
Flowmasters - Flowmaster American thunder exhaust system.Its a 2.5" dual exhaust system.This is the dual exhaust system that has the transverse style muffler.1muffler,2 pipes in and 2 pipes out.Its about 3 years old.The summit part # is FLO-17104 its a cat back system.Originally sells for $369.95.Had to do a little modifications to make it fit ,but works great.Asking I will be removing when the rear comes out.$175+shipping
SBC 461 Double Hump Heads 2.02/1.60 Valves - 461 sbc double hump heads with all new manley stainless valves,keepers,locks and retainers.They are fitted with .510 lift springs with some mild bowl porting.These are a match set of heads fresh out of the machine shop.They have 160cc intake runners and have 62cc combustion chambers. $500+shipping
Stock 400 SBC Flex Plate, automatic, Ex Condition. $25+shipping
Chevrolet Bowtie Low Profile Chrome SB valve covers w/
baffels and Chevy logo. $50+shipping
Edelbrock 14" Air Cleaner w/ New filter element
Perfect Condition. $15+shipping
Brand New zz4
Roller Cam. $150+shipping
Brand New SBC Solid lift Lunati cam .517int. and
.543exh with 1.5 rockers. Rpm range is 3200 to 6500rpm.
$100+shipping
SBC or BBC Hitachi Mini Starter, used for 1 week, sold motor.
$125+shipping
Weiand TEAM G Intake Manifold SBC 7530 - TEAM G intake for sbc.Ideal rpm range 2000-8000.All threaded holes in excellent condition.Used for 4 months. $115+shipping
New IMCA Oil Pan - SBC 7qt oil pan and matching pickup tube. Designed for a 2 piece rear main block having the dip stick on the drivers side. 1959-1979 Blocks. 7 1/4" deep at the rear sump and 3" right side kick out. Pan comes with built in oil baffles and 2 trap doors for oil control. Pan is raw and unpainted finish. $65+shipping
SBC Tall Chrome valve covers with hardware and chrome oil pan. Good condition. $50+shipping
302 Bare Long Block - Good condition $100 pick up only
93 Mustang GT Front Clip - 2.5" cowl hood, fenders, front bumper.
Mint Condition $600 pick up only
Offers Excepted - I do need a set of 28x11.5x15 drag radials/et streets/hoosier quick time pros. Must have at least 90% tread.
If you would like pictures please leave me your email. Thanks!
Misc Chevy/Ford - Motor, Parts, etc
blake_racing
86 Grand National
79 Camaro Z28 (406sbc)
87 Mustang Notch (406sbc) SOLD
80 Camaro SOLD
80 Camaro SOLD
PONY GUY
Re: Misc Chevy/Ford - Motor, Parts, etc
do you still have the flex plates for the 400 sbc are they both for auto or do u have one for manual also
blake_racing
Yes I still have them and they are both for an automatic. Thanks!
86 Grand National
80 Camaro SOLD
80 Camaro SOLD
