auto to manual
DomOH 5 OH
auto to manual
Post by DomOH 5 OH »
i just purchased a notch roller which was an auto. does anyone know what type of fabrications i need to do to get a clutch pedal installed?
rednotch
Re: auto to manual
Post by rednotch »
just need to pick up the pedals from a junk yard, they just bolt in.
Other then that you will need to inlarge the trans tunnel hole for the shifter, if you find the pedals in a yard take the spot welded sheet metal on top of the trans tunnel too so you can seal the shifter whole with a factory boot..
