Rear Gear recomendation
oldsguy
Post by oldsguy »
Hello all
With winter comming close I plan to upgrade the rear in the Cutlass. Right now the car has a 330 but I in the process of building a 455 to replace that.
The car is a street car with occational track time. I am sticking with a olds rear so my choices are limited. I can get a 342 355 390 or 430 gears,
What are everyones opinions
67 Cutlass
BALDY406
Re: Rear Gear recomendation
Post by BALDY406 »
With all the torque that 455 will produce, you won't need much gear. I'd go with the 355's since it's more of a sreet car than a track car. I had a 74 Cutlass with a stock 350 rocket. After i blew the 3.08 rear apart, i put in a 3.55 10 bolt out of a chevelle and it was perfect. Damn i miss that car :cheers:
