cobra t5 rating
DomOH 5 OH
cobra t5 rating
Post by DomOH 5 OH »
just bought this tremec t5 needed second and found out it is a cobra trans
( M7003 Z ) 249
how are these. how much abuse can these handle?
also i am doing a aod to t5 swap, do i need a certain flywheel or can a stock replacement work. asking for balance reasons.
Silverstang84gt
Re: cobra t5 rating
Post by Silverstang84gt »
The T5z is a strong trans, and as far as the balance goes depending the year of the engine a stock flywheel should be fine, just get it resurfaced as long as you get a flywheel with it for the swap, not knowing your experience the AOD flexplate wont work but if you know then disregard that statement lol good luck.
Jim
Horsepower is how fast you hit the wall, torque is how far you take the wall!
