Standard Holley Regulator ?
colormebad
Post by colormebad »
I see alot of people running your regular up to 9pound pressure regulator with larger fuel pumps...Talked to one guy running 1 for the carb only and 3 others for 3 stages of nitrous...I ran these regulators in the past but didnt know what the downlow was ' using them with larger pumps...They seem to be working fine for lots of people and way cheaper...Another guy said he went through 3 higher reg's and started using the standard holly & has had no problems....
d2racer
Re: Standard Holley Regulator ?
Post by d2racer »
they work good , when i converted my stang to carb i wanted to leave the in tank pump but could not fins a return style regulator that would step the pressure down to 9 lbs until i used an old holley one dead head i had laying around right at the carb
mbetter95
Post by mbetter95 »
I'm getting a set of mickey t slicks from my uncle to try to see if they hook if so I'm going order set of et streets and stray away from hoosier hopefully I can sell the drag radials I got help off set the price of new ones
"M Better"
