Q8 Rules and Payouts?
News, Events, Info... Talk about your local track!
Hollywood
Post by Hollywood »
What are the rules and payouts this year?
Michelle
Re: Q8 Rules and Payouts?
Post by Michelle »
2008 Ultra Quick 8 Rules
2008 ULTRA QUICK 8 for NMCA Type Cars
POINTS SYSTEM & PAYOUT
Run on Select Sundays.
See complete rules listed below.
Minimum Payout for 8-Car Field (Payout To Be Announced)
Winner 3 points
Runner-Up 2 points
Semi-Finalist 1 point
1st Round Loser 0 point
Attempting to Qualify 1 point
Qualifying in Top 8 1 point (Alternates will not receive this point)
#1 Qualifier 0 point
Entry Fee $100 ($35 to payout, $35 to points fund)
Points Sign Up Fee $50
If there is a tie for a position, the tiebreaker is as follows: A. Number of elimination wins. B. The rating point system: Each driver will be rated according to his/her position in the standings. The rating system will begin after competition on the first points day (April 27). The rating will be as follows: If a racer is in first place, one rating point will be awarded; second place will receive two rating points, third place will receive three rating points, etc. If two or more racers are tied with the same amount of points for any position, they will each receive the same amount of rating points i.e. tied for fifth each racer gets five rating points. The rating numbers will be increased based upon what place the racer is in. This will continue through the end of the Ultra Quick 8 Points Series. On the last points day, if a racer is in seventh place and earns enough points on that day to move him/her into a tie for third place, the racer with the lower rating points will finish the year in third place and the higher rating points racer will be fourth. The only way a runoff will be necessary is if the earned points, number of wins, and rating points are the same. If after the tiebreaker, a result for a position has not been determined, a one-run run-off will occur. NOTE: Top 8 points earners after August 31, 2008 will receive an embroidered Jacket courtesy of Raceway Park.
BODY-must retain its original appearance and profiles. Must be OEM production body, no panel cars. Aftermarket lightweight replacement panels are limited to the hood, fenders, hood scoop, hatch, doors and bumpers. One-piece front end is acceptable, but must be finished to retain a factory look, including grill (allowances will be made for turbo/blower placement). All vehicles may also use lightweight replacement windows, but must retain as near a factory appearance as possible.
Aerodynamics – Radical Body modifications designed for aerodynamic advantage are strictly prohibited. Aftermarket lightweight replacement parts should OEM dimensions.
Firewall – Stock location, steel firewall required, may be notched for clearance for bell housing, headers, distributor, blower, or inter-cooler. Non-stock Firewall location for engine setback - Add 50lbs.
Grill - A full-production grill is required for the body style used. NO air brushed grill.
Interior – A full OEM type of dashboard must be retained. Car must be finished to a neat appearance
Chassis - Front frame rails must remain in the stock location. Tubular cross members and core supports are permitted. Only stock frame or ‘back-halved’ combinations are permitted, no round tube chassis cars allowed. Lower control arms must be attached to a K member/sub-frame. A-arm cars may relocate lower A-arm mounts for pan clearance. If the stock frame is notched, it must be reinforced in a manner acceptable to NHRA. Any strengthening members may be added to a stock frame. Front-wheel-drive conversions are permitted provided stock firewall and stock-type front suspension is retained.
Note: Old School square tube cars with strut or A-arm can run in the class with no additional weight penalty but may not go faster then the chassis is certified for by NHRA.
DRIVETRAIN
Automatic Trans - Any OEM/Aftermarket automatic transmission (Bruno etc) acceptable, max 4 forward speeds
Manual Trans naturally aspirated ONLY - Aftermarket clutch less transmissions are allowed with a maximum of five forward speeds. – Add 150 lbs
EXHAUST
The headers must be connected to a working exhaust system, mufflers.
Turbocharger - A single Turbo up to 106mm or twin Turbo's up to 88mm each. A single turbo bigger then 106mm must run at twin turbo weight. See Below - Turbocharger Rule Deleted
Aftercoolers/Intercoolers - Air to air or air to water intercoolers are the only systems acceptable. Water and ice are the only two acceptable components allowed in reservoir.
Nitrous- Any number of systems allowed. Maximum of 2 - 15lb capacity bottles only
STREET EQUIPMENT
The following operational street equipment is required: Head lights or driving lights to be used with hidden headlights, tail lights, and brake lights. Sponsor decals only on glass.
TIRES
The tread of tires must not protrude outside of the exterior of bodyline at top of tires.
Fuel
Gasoline or Alcohol, NO Nitromethane
POWER ADDERS – Single power adders only.
ALL BASE WEIGHTS WITH 10.5 TIRES
NATURALLY ASPIRATED COMBOS
2,400 Lbs. – Small Block
2,600 Lbs. – Big Block
NITROUS OXIDE COMBINATIONS
2,600 lbs. – Small Block
2,900 lbs. – Big Block
BLOWER APPLICATIONS
3,000 lbs. – Centrifugally Supercharged
3,000 lbs. – Roots Blower
3,100 lbs. – Whipple Blower
TURBO CHARGED APPLICATIONS
2,800 lbs. – Single Turbo – Small Block
2,900 lbs. – Single Turbo – Big Block
3,000 lbs. – Twin Turbo – Small Block
3,100 lbs. – Twin Turbo – Big Block
DEDUCTIONS/ADDITIONS
BIG TIRE ---- ADD 100LBS
CLUTCH ---- ADD 100LBS
RULES ARE SUBJECT TO CHANGE AT ANY GIVEN MOMENT TO KEEP PAIRTY IN THE CLASS
Adders:
Manual/Clutchless Transmission naturally aspirated only – Add 150 lbs
Non-stock Firewall location for engine setback- Add 50,
NOTE -Single Turbo bigger than 106mm will race at Twin Turbo weight.
WHEELBASE/WHEELS
Wheelbase - Must retain stock wheelbase with a maximum variation from left to right and front to back of 1 inch
Race Procedures Qualifying , Race & Tech
No tow vehicles allowed past scales without permission from scale person, cars must drive to scales whenever possible.
NHRA Pro ladder. i.e. 1 vs. 8, 2 vs. 7, 3 vs. 6, 4 vs. 5.
Quicker car has lane choice
Qualifying will be done pro style. In pairs as often as possible, and in case you are making two qualifiers, you will run each lane one time, you will not be allowed to run the same lane twice.
You must attempt to qualify with a racecar capable of running 8.99 or quicker.
#1 qualifier must run first round to receive award.
If you cannot run first round, tell a track official.
Quickest 8 cars qualify.
Eligibility to be determined by the Raceway Park Management.
Cars and/or drivers found NOT to be in compliance with these rules are subject to disciplinary action up to and including expulsion from the Quick 8.
Once all cars leave the bleach box area they may only cross the starting line one time for their burnout prior to their run. Example: Once you back up over the starting line after your burnout, the remainder of the race shall be forward motion only. If you cross the starting line again after this burnout, you will be disqualified. Racecars must back up after their burnout under their own power -- no pushing the racecar.
Oil Down Rule: If any racer leaks oil or any other fluid on the racetrack that requires a large clean up with the clean up machine, jet, track crew, etc., you will receive one warning for the season. Any incidents that require clean up after that one warning will cost you one point. This action is necessary for the safety and quality of the Ultra Quick 8 show. We hope this policy will encourage racers to triple check their racecars to prevent leakage on the racetrack.
Any racer in Quick 8 that refuses any post race tech procedure will be expelled from the Quick 8 for a period of two years from date of infraction and subject to penalties from the NHRA.
If a competitor is disqualified for any infraction (ie. Crossing center line, failing tech, etc.) his or her competition may be reinstated on an per incident basis by management.
Ultra Quick 8 windshield banners must be displayed in the center of the windshield and area mandatory in order to pass tech inspection. The first banner is no charge. Additional banners will cost $10 and are available from the tech inspectors.
Note no car will be allowed to go faster than the Chassis is Certified for by NHRA.
All NHRA safety rules will apply for your combination including Driving Suit.
This is for your SAFETY and the car next to you.
2008 Dates for Ultra Quick 8
Sunday April 27 Along with Sunday Points Program. Points
Saturday June 7 Along with Night of Thrills Show Invitational
Sunday June 29 Along with Sunday Points Program. Points
Wednesday July 9 Along with Summer Motorsports Spect. Invitational
Wednesday Aug. 6 Along with Jet Car Nationals Invitational
Sunday Aug. 31 Along with Sunday Points Program. Points
RULE CHANGE - EFFECTIVE THURSDAY, APRIL 24, 2008
No limit on Turbochargers.
This rule is now deleted:
Michelle
Post by Michelle »
Please see the rules post. A rule change was made today.
