KWIK WAY SPRAY WASH CABINET TO DEGREASE ENGINES, TRANSMISSIONS ETC. ROTATING TABLE AND HIGH PRESSURE JETS SPRAY THE PARTS 360* AND HEATS THE SOLUTION TO 180 DEG. THIS UNIT HAS ONLY DONE ABOUT 20 ENGINES SINCE NEW, AND IS IN NEARLY NEW CONDITION. $4500.00
NEVER USED AMPRO (SUNNEN) DEGREASING OVEN. THIS OVEN WILL PROCESS 8 ENGINE BLOCKS OR 80 CYLINDER HEADS AT A TIME. YOU WILL ONLY NEED TO OPERATE IT ONE DAY A WEEK. I PAID OVER $15,000 FOR THIS AND I NEVER HOOKED IT UP. $10,000 OR B/O.
STAINLESS STEEL TRANSMISSION DEGREASING MACHINE, FROM A CLOSED AAMCO TRANS SHOP. ELECTRIC HEATER. $1500.00
20 TON PRESS WITH HANDS FREE AIR/HYD PEDAL PUMP. $350.00 - SOLD
20 TON MANUAL PRESS $200.00
5HP AIR INGERSOLL RAND INDUSTRIAL COMPRESSOR $1000.00
AIRCO MIG WELDER 100% DUTY CYCLE $500.00
STEEL PIPE/TUBING RACK FOR STORING LONG PIECES $200.00
WORK BENCHES $75.00
STORM VULCAN KOTE-A-WELD CRANKSHAFT WELDER $2500.00
VAN NORMAN (RELS) 203 DRUM/ROTOR LATHE (NO ACCESSORIES) $750.00
SUNNEN HONING MANDRELS FOR PISTON PINS, RODS, SMALL. MEDIUM AND LARGE BORE SIZES $75 TO $200 EACH. LOTS OF SUNNEN HONE TOOLING AND STONES.
R-12 A/C RECYCLING MACHINE (2 AVAIL) $350 EACH
ANTIFREEZE RECYCLING MACHINE $250.
WINONA VAN NORMAN VALVE GUIDE & SEAT MACHINE WITH NEWEN 3 ANGLE FORM TOOLING AND ALL NECESSARY TOOLING. $6500.00
CYLINDER HEAD STRAIGHTENING OVEN WITH FIXTURES, HARDLY USED, $2500.
SUNNEN AN STYLE CYLINDER HONING STONE SETS, $10 EA. NEW, $5 EACH USED
SNAP ON TORQUE WRENCHES, CALIBRATED, I JUST HAVE TOO MANY, $150 EACH
CRAFTSMAN DRILL PRESS $100.
HEAD/BLOCK 38" STRIGHT EDGE $50.
STEEL ROD VISE $75
CRAFTSMAN AND MAC TOOL CHESTS AND BASES, SEVERAL AVAILABLE.
SIOUX CYLINDER HEAD REPAIR STATION FOR GRINDING SEATS, PORTING, ETC. $500.
CBN 1/2" NEW CUTTING BITS FOR RESURFACERS $100 EACH.
NEW NORTON CUP STONES FOR FLYWHEEL GRINDER, $20 EACH
PLEASE CALL 215-946-0707.
JEFF
LEVITTOWN, PA.19057
AUTO REPAIR & MACHINE SHOP EQUIPMENT
jeffmotorman
jeffmotorman
Re: KWIK WAY DEGREASING SPRAY WASHER AND SHOP EQUIPMENT
ADDED POSTINGS TO THE LIST.
jeffmotorman
Re: AUTO REPAIR & MACHINE SHOP EQUIPMENT
I HAVE MORE EQUIPMENT THAN ON THE LIST AVAILABLE. CALL 215-946-0707 WITH YOUR NEEDS.
JEFF
LEVITTOWN, PA. 19057
JEFF
