Big Tire OUTLAWS come to etown on May 22, 2011
1/4 MILE
Rules:
• 3,200 lb. base weight
• No Pro Modified cars
• Square tube entries permitted
• Factory produced cars with VIN numbers only
• Single (one) power adder only
• Any tire size allowed
• Oil retention device required
• Courtesy staging in effect
• Auto start on, set at 7 seconds
• All NHRA safety rules, license, chassis requirements in effect
• Any Transmission allowed
• No Screw Blowers except D rotor add 200lbs.
• No Twin Turbos single only 106mm max 550ci max
• No 5.3 Bore spaced engines
• No Twin Blowers
Deductions/Additions:
• Naturally Aspirated – Less 600 lbs.
• Single Carb – Less 75lbs.
• Nitrous 650 & smaller – Less 200 lbs.
• Small Block Boost – Less 200 lbs.
• Small Block N20 – Less 500 lbs.
• Round tube entries – Add 100 lbs.to base (no panel cars, real Vin numbered car only)
• 5.2 bore spaced add 100lbs must be 25.3 spec
• BB blower alcohol 14-71 add 100lbs
Notes:
A) If your car exceeds 3200 lbs and is faster than 7.50 ET, it must be certified to 25.3 sfi.
B) Rules may be adjusted to even the qualifying field.
More info. to follow
**etown big tire OUTLAW rules/date enclosed**
- moody34
"...oh god, did you eat all this acid? You better pray to god there's some thorazine in that bag or you're in bad f+*%ing trouble!"
- moody34
Re: **etown big tire OUTLAW rules/date enclosed**
