79 Malibu /Back Half/10.5/Big Tire/Pro Street/8.50
Moderators: lightemup, mouth
Hotrod1451
Post by Hotrod1451 »
79 Malibu.
Jerry Bickel Race Cars Round Tube Back Half.
All Alum Work is powder coated on both sides.
Car is all Steel Except hood and Trunk lid.
All Factory Working Glass.
Lights, Turn Signals, Brake Lights, Even has a horn.
3050 Pounds Without a driver.
New Carpet, New headliner.
PA title
Tig Welded Funny Car Cage NHRA 8.50 Certified.
Engine plate.
2 Alum Seats.
Belts Dated 9/13
4 Wheel Disk brakes.
Weld AlumA Stars.
9 Inch Ford with ladder bars and Coilovers ,4.56 gears
Strange Center Section W/4.56 gears.
Moser Axels W/Big Studs
Has M/T 33X10.5 W 15s on it but will take a 16 tire.
468 BBC With Brodix -2 Alum heads.
4 bolt mains with Billet caps.
Scat Steel Crank and H beam Rods W/ARP bolts
Very Low Runs.(under 21)
Roller Cam, ATI Balancer,1050 Dominator.
MSD 7AL3 Box And pro power Coil
MSD Distributor and Wires
Trans Specialties Pro Line 2500 Glide With 8 inch Converter.
1.80 first gear, Trans Brake.
Digital Delay, Crossover Delay Box.
Lemons Ceramic Coated Headers with Collector Mufflers.
NHRA Approved Header collector Tethers
Car Was a original Quick 8 car and has been in the 7s.
Needs very Little to be a Street car.
Nice 07 18ft Trailer available with car.
Many Pictures Available.
Make a great 8.50 car.
Run 9s all day and never go over 180 degrees water temp.
$24,000
Trade for 60s-70s Manual trans Muscle car
All Throttle,NO BOTTLE
Hotrod1451
Re: 79 Malibu /Back Half/10.5/Big Tire/Pro Street/8.50
Bump :hay:
Hotrod1451
Bump again
