All Tube car 71 Ford Mustang Mach 1 - $9990
First off..I'd like to say I've been out of the racing loop for 10+ years. I've priced the car on advice from 2 friends who are still into racing. The price is 'what they would expect to pay' for the car and the included Components. If it's out of line and you're interested..drop me a line\txt
You can txt me also at 716.870.8175
Located in the Buffalo NY area
Car was completely recaged by Vito Antonicelli in 1999 to pass NHRA 9:90 certification (tubing wall thickness was
to small). Very few passes on the car since. Last certified in 99 and last pass in the car was in 1999. Anything
SFI dated will obviously be expired (Belts, net etc).
Fiberglass front bumper, fenders, hood, doors.
All Lexan windows
Removable driver’s door
Removable steering wheel
Windows net (expired)
Driver and passenger seat with belts (expired)
Set up for a BBC
Headers
4" exhaust
Midplate
Tranny included:
Fresh 2 speed powerglide
'Pro' trans break
TCI Scattershield
Flywheel shield
Removable tranny tunnel
Hurst reverse 1/4 stick with housing
Back:
CE adjustable coil overs
'N' case Ford 9"
Reinforced rear end housing
Full spool 4:11s
Hardened axels
Drive shaft
Driveshaft loop
Ladder bars with track locator
17.5 x 32 Mickey Thomason street slicks
Charging lugs
Master on\off switch
LineLock
Parachut
Trunk:
20 gallon (?..might be bigger) fuel cell in rear
Dual battery mount
Paxton fuel pump
Up front:
Rack and pinion Steering
Coil overs
Big aluminum radiator
Electric cooling fan
Trans cooler with remote filter
Ignition coil
2 gallon 'NOS' fuel cell with pump
Throttle linkage
NOS line and bottle brackets
Electronics included:
Crossover delay box
MSD 3 stage retard box
MSD 7AL-2 ingition
Autometer gauges:
Monster tachometer with shift light and oil light
Volts
Water
Oil
Fuel
What you get is basically a complete car minus the motor. Back then I thought I had a transmission issue so I had it
rebuild. It turns out I cracked the engine block and bent a few valves in my original motor. Pulled the motor with
the intentions of replacing it...then life took over...and the car has been in storage ever since.
The rebuilt tranny has zero passes..it was brought up on the brake a couple of times...then the motor was pulled.
I owned the car from 1995 and raced it from about 95-99. Never had any issues of any kind with chassis related
stuff. I had a buddy of mine talk me into putting a bigger cam in it that ended up breaking some motor parts (bent
valves etc).
The car always went straight and was actually quite boring to drive. I have no recollection of short times as
it's been way to long. This is the old Inky Brothers (spelling?) Mustang for the local crew
More pics here
http://s196.photobucket.com/user/m0nste ... ry/Mustang
1971 Mustang Mach1 All Tube Car - no motor
MonsterBash
Jump to
- Event Coverage
- ↳ Event Coverage
- General Items
- ↳ General Chat
- ↳ Video\Pictures
- ↳ GoneDragRacing.com Store
- General Racing
- ↳ Racing schedules
- ↳ Index Racing
- ↳ Driver Profiles
- ↳ Track Rentals
- The Burn Out Box!
- ↳ Atco Raceway
- ↳ Outlaws @ Atco
- ↳ Cecil County Dragway
- ↳ Raceway Park - Englishtown
- Technical Knowledge
- ↳ General Tech
- ↳ Engine
- ↳ Transmission & Driveline
- ↳ Suspension
- ↳ Nitrous tech
- ↳ Turbo Tech
- ↳ Supercharger tech
- Car Shows
- ↳ PA Car Show Events
- ↳ NJ Car Show Events
- ↳ MD and DE Car Show Events
- Classifieds
- ↳ Cars for sale
- ↳ Parts for sale
- ↳ Parts Wanted
- ↳ All your other Shiii....stuff...
- Test
- ↳ Budd Olsen Speed Supplies
- ↳ Pinks!
- ↳ Shakedown @ E-Town
- ↳ 2010 Calendar Discussions
- ↳ 2011 Calendar Discussion
- ↳ Ultimate Outlaw Shootout Series
- ↳ Fonse Performance
- ↳ Bonehead Performance
- ↳ Kasper's Corner
- ↳ Wiked Designs
- ↳ American Muscle
- ↳ TRZ Motorsports
- ↳ Collingdale Performance
