Up for sale is my 2000 ws6 trans am. It has t-tops and power everything including cruise control. It has quite a bit of work done to it. It has 89k original miles on it. The car has only been driven 2-4 times a month over the last 2 years. It is now off the road and has been since feb 2013. But i still drove it some before taking it off the road. I'm only selling because i can longer afford this hobby so it has to go. The car has been to the track and has gone 11.9@ 114 mph with a 1.72 60ft.( It will lift the left front wheel off the gound 6"s on a good launch. I have Youtube videos of it at the track if interested. I have adjusted the suspension and added a bit larger throttle body and an asp 25% underdrive pully. So it will go into the mid 11's with some more tuning. Below is a list of all the parts installed and also extra parts i have that i did not install. I also have the factory wheels with good tires and micky thompson drag radials.
The car still has the a/c system installed but two of the lines need to to be replaced. no front sway bar but it still handles like it does. The car has it's nicks and light scratches. Its not a show car but it looks good for it's age. The bad side, The overdrive is not working but its a pretty easy fix. The fourth gear servo needs a longer pin for the 2-4 band. All the other gears including reverse work perfect.
The passenger side seatbelt guide is broken. The carpet needs a good cleaning in front of the back seats or replace it with light weight!
This car passes NJ inspection!
See videos of the car on Youtube. Search Mattysta00
comp custom grind cam 591 601 115lsa
Level 4 Built transmission with red clutches and carbon 2-4 band
PT 4400 stall convertor
85mm carbon fiber style lid
85mm corvette MAF
polished 85mm throttle body
LS6 Intake
36# Ford svo injectors
asp 25% underdrive crank pulley
k&n filter
Triple gauge pillar.Wideband 02 gauge hooked up and electric fuel pressure gauge not hooked up(needs sensor)
Hooker ceramic coated headers
The current y-pipe( i can't remember the brand) has gutted cats for visual reasons and needs to be tightened up a bit as its a bolt on and is leaking slightly,
Flow master cat-back
UMI double adjustable torque arm
single adjustable rear control arms
front hal 12 way adjustable shocks with 150# springs
Rear 3 way adjustable summit drag shocks
3:73 motive gears with a torsen posi and t/a rear diff support cover.
weld xp draglites front and rear (rears are 16" and rare) with micky thompson et streets in the front and the tires in the front are brand new radials rated for 140mph.
Tuned with My efi live software
Pioneer cd player.
installed.
Not installed:
used off road y-pipe
If anyone comes close to my asking price i will include the drag wheels, the efi live tuning software and the offroad y-pipe.
Asking 11.5k O/BO Will take partial trades+Cash Looking for an enclosed trailer, Cargo Van, Motorcycle, Quad, Let me know what you have. No straight trades.
2000 Trans Am WS6 Street/Strip
MattysTA
