68 Pontiac Firebird Drag Car
Moderators: lightemup, mouth
AndytheFordGuy
Post by AndytheFordGuy »
FOR SALE! Running 68 Pontiac Firebird - No Title
'72 455 block bored .040 Over - 920cfm Holley, Torker II, #16 heads matched and ported, .555" lift solid lifter cam, Roller Rockers, Stock forged crank, H Beam Cat rods, electronic ignition with 2 step rev limiter, HPHV Oil Pump - welded, 4400 stall ATI converter, Reverse valve body and transbrake on built TH400, Fabbed steel drive shaft, built 12 bolt with spool and moser axles, CalTrac bars. Fiberglass front end, ten point roll cage, ratchet shifter. removable steering wheel, 10 gal fuel cell, All new wiring and relays, aluminum radiator, electric fan and water pump.
Very consistent. Hate to see it go. Raising money for kid's JR dragster
$7500 or best offer with throw in a enclosed trailer for an extra $2500 and lots of starters and extra parts if you ask REAL nice!
Frylok
Re: 68 Pontiac Firebird Drag Car
Post by Frylok »
Wheres it located?
