Valve covers without breathers???
BigRedMachine
Post by BigRedMachine »
Getting ready to order a new set of valve covers for my street motor. Im looking at the fabbed aluminum valve covers. Question is will I need breathers on them , because they dont come with breather holes???
1968 Chevelle
1985 Mazda RX7-Under construction-SBC swap
2001 Pontiac Trans Am WS6
2001 Chevy Tahoe Z71
1982 Chevy K10 on 44" Groundhawgs
WDCreech
Re: Valve covers without breathers???
Post by WDCreech »
You need some way for fresh air to get in the crankcase to replace the dirty air air that is drawn out by the pcv, or vacuum pump.
Bill
1964 tube chassis GTO, Indian Adventures 606" Pontiac, w/435 cfm Super Chiefs, dual 1295 cfm Dominators, glide, and a Fab 9" rear. 2700 lbs. Best pass, so far; 1/4 mile, 8.2550 @ 164.17; 1/8 mile, 5.2920; 60', 1.1981; All Motor on Gasoline
BigRedMachine
right. I was just wondering if those valve covers were specifically made for engines with vaccuum pumps or can you put breathers in them??
1968 Chevelle
Turbo chevelle
Post by Turbo chevelle »
You should be able drill a hole in them the exact size you need for the breather grommet.
One on each side would be best.
cheers Marc
PROFESSIONAL PHOTOGRAPHER
AUTO, FAMILY, BABY, WEDDINGS, CORPORATE, SPECIAL EVENTS
302-668-3456
BigRedMachine wrote:right. I was just wondering if those valve covers were specifically made for engines with vaccuum pumps or can you put breathers in them??
Just drill your own hole where you want/need it.
BigRedMachine
thanks for the visual aid.
thats what Im gonna do
1968 Chevelle
K-Star Automotive
Post by K-Star Automotive »
I also use a hole saw, here are a few tips.
Use a few pieces of masking tape and lay-out the location of the holes. I usually put 2 or 3 on top of each other. It's a lot easyer to remove the tape if you don't like the hole location then trying to fix the hole after you drill it.
I put both holes in the front of the valve covers because there seams to be less oil splashing around in the front under acceleration. On the small block Chevys I locate them in line with the 2 bolt holes that attach the valve cover, that will place the breathers between the rocker arms.
As a rule the gromment for the PCV valve will need a 1" hole while the gromment for the breather needs a 1 1/8" hole. Measure both of them before you start drilling.
Have someone there to hold the valve cover while you drill it. Those hole saws have been known to grab some time, removing the drill from you hands and throwing the valve cover and the drill on the floor. I made a holding fixture outof wood and some long deck screws, and clamp the entire thing on to my work bench.
Be real careful taking the burr off the hole, one slip and you have a scratched valve cover. I let the tape on until i am totally done with the job.
Keith
K-Star Automotive
Performance Engines.
