rear disc brakes
jmscamaro
rear disc brakes
i have an 86 camaro that had rear drum brakes and change the rear too rear disc brakes. should i keep the orginal metering block, and do i need to change the master cyl. thanks for the help james
1990Lx
Re: rear disc brakes
yes you should change your master cylinder and propotioning valve/metering block. the disc brake setup requires more pressure and volume to work correctly and to be safe. Also the braking bias is slightly different from disc to drum. I would swap the parts now to be on the safe side after all, you only want to use your brakes to stop...right?
It runs on hopes and dreams but its getting there
