89 gt roller f/s
Posted: Fri May 09, 2008 2:38 pm
89 gt roller original black car repainted. 75k miles no motor no trans..do have 351, 302, 460 blocks with cranks and c6 core that i can throw in if i get what im asking. car has completely tubular qa1 front end. control arms k member caster camber plates coil over with...175lb springs flaming river manual rack and steering shaft. 6 point bar monster tach water temp and oil pressure in pod on dash, suframe connectors, alum rad with upr ss hold down 6a box, moroso battery box (have to finish wiring) upr manual brake concersion have to flare 3 lines and install t fittings) 8.8 rear 31spline axles full spool 3.73 gear c clip eliminators lakewood lift bars, double adj uppers. sumped stock tank -8 feed -6 return mallory bypass regulator. lines need to be hung and regulator needs to be replumbed. no efi parts on the car setup for carb...has 2in cowl hood with draglites, good m/t front runners with shitty et street radials out back...cant afford to build the car and hate to see it sit. $3200 firm!
