key wont start
BIGWOOD
key wont start
Post by BIGWOOD »
having problems... im sure its an easy fix but i cant figure it out... got the motor to fire up by jumping the celnoid...but cant get the key to turn it over... it was a 4cyl automatic car that i converted to stick and 8cyl carburated ...is it the wires that plug into the pedal assembly? could that be wrong? is there a wire somewhere that isnt hooked up? please pm me... thanks!!!
oh the car is a 93 notch
93 Notch
98 Dodge sst
67camaro101
Re: key wont start
Post by 67camaro101 »
make sure when you turn the key as if you were going to start it you have a hot wire going to the cylinoid. also if its equipped with a neutral safety switch check that.
Coming Soon
www.bbphotondesign.com
Supporter of Gonedragracing
Proud supporter of WTF Web Design
rednotch
Re: key wont start
Post by rednotch »
5 spd yoiu need the red. blue stripped wire plugged in to the clutch pedal.
if its an auto you need to make a jupper wire that for the harness... you can also do that if you want to bypass using the clutch...
since it was an auto the factory harness from the car should have that jumper wire in it all ready.. its ussualy still taped the the main harness on autos so you have to dig for it.
