RPM activated switch
All you bottle babies post here!
Qwik Cobra
Post by Qwik Cobra »
Just curious how many of you guys you MSD "window switches" the RPM activated switch they have...I swear by them. Even in an automatic. In a Stick shift, it would be mandatory.you never know what the hell can happen, its good to know that shit will shut off outside of the rpm range chips you put plugged
you guys all use them?
You Cant Make a Hoe a Housewife!!!!
Addicted to the Streets!!!
Big Dogs Racing Team
Re: RPM activated switch
Post by Big Dogs Racing Team »
I use the RPM Activated Switch for the electric shifter only, nitrous is WOT, connected to a relay and then to the transbrake button...
RIP goDragRacing.com 1998 - 2008 - Thanks For The Memories.
mike
Post by mike »
Big Dogs Racing Team wrote:I use the RPM Activated Switch for the electric shifter only, nitrous is WOT, connected to a relay and then to the transbrake button...
What happens if you popped broke something in the driveline and the motor shot to the moon on the squeeze?
BBC on spray...
KOP prove me wrong :)
As soon as I let off the throttle the nitrous is off, but if such a thing would happen, heck, bite your tongue and let it happen and buy a new motor...I guess. But a good point there Mike.
i made my own nos controller box with 2 rpm switches and timing controller tied with 2 on/off/on relays works great and no mater what the nos only comes on in the window and anything can shut it off
mike
Post by mike »
Big Dogs Racing Team wrote:As soon as I let off the throttle the nitrous is off, but if such a thing would happen, heck, bite your tongue and let it happen and buy a new motor...I guess. But a good point there Mike.
Just curious. I would think if you shift your car at 7400 or whatever, that you would have a window switch for the N20 and an rpm limiter for the motor set to 7600 just to save the parts. I would think just the rpm limiter could cause quite a pop once your rpms dropped before the spray stopped.
BBC on spray...
You my attention Mike, I'm gonna talk to Steve Johnson about a setup, good guy there.
I shifted at 7200, but the cam will change things a little.
You might have saved a motor here.
mike
Post by mike »
Definetly something I am not know for lol.
BBC on spray...
mrhockey
1000ft
Post by mrhockey »
I shift at 7700 and the motor goes somewhere around 8000-8200 through the traps. My rev limiter is set at 8500 and my window switch for the nitrous is set to 8400. That way the spray is off BEFORE you start dropping cylinders to limit RPM. I also have a window switch on the low side set at 2500 RPMs in case the motor bogs on the line it will shut it off instead of blowing the carb off.
wazslow
Post by wazslow »
Bog, that never happens with those little tires! lol
NEVER TRUST A 100 RPM DIFFERENCE IN CHIPS !!! OHM TEST THEM TO BE CERTAIN . AND NEVER LET ANOLOG OVER RIDE DIGITAL THE DELAY IS ENOUGH TO OVER LAP AND """BANG""" THE REV LIMIT HITS BEFORE THE NOS IS FULLY OFF
moody34
Post by moody34 »
Going to run a WOT switch to activate the window switch in turn giving juice to the nitrous relay. It's an msd digital window switch. Gonna set the lowside at 3000 and high side at about 6600, 200 rpm before high side chip. Any thoughts?
"...oh god, did you eat all this acid? You better pray to god there's some thorazine in that bag or you're in bad f+*%ing trouble!"
mrhockey
1000ft
Post by mrhockey »
moody34 wrote:Going to run a WOT switch to activate the window switch in turn giving juice to the nitrous relay. It's an msd digital window switch. Gonna set the lowside at 3000 and high side at about 6600, 200 rpm before high side chip. Any thoughts?
Perfect.
