jeffmotorman wrote:Did you install the cam retainer thrust plate on the engine block behind the timing gear?
Was the oil gallery crossover plug installed at the rear of the block just beneath the intake manifold?
Were the oil gallery plugs installed at the front of the block behind the cam timing gear?
Soak the lifter rollers in a tub of oil before installation?
Oldsmoduck wrote:Looks like the lifter/s rotated, check those dogbones or whatever is supposed to hold the lifters in position.
