not racing related, F350 blinkers - help
BigEd
Location: Delta, Pa - in the middle of no where, 30 minutes from everything
Post by BigEd »
Couple of months ago blinkers quit working in the dually. Not all at first, sometimes they would work, sometimes they would flash real fast and sometimes not flash at all.
So I go out and buy a new flasher relay (LF-12) the other day and put in this morning before going out and it worked for about 10 miles - just stopped, no click from the relay.
Now what?
I was reading over on Dieselstop that it maybe the actual blinker switch lever in the steering column.
Anyone have any expierence with this before I go and buy a $80 switch?
drummerdad
Re: not racing related, F350 blinkers - help
Post by drummerdad »
Im not familiar with the ford wiring, but does it only have one flasher? Does everything else on the stalk work? And do you have a meter to check for voltage at the blinker?
Do-It-To-It
Post by Do-It-To-It »
sounds like you have a switch problem ie: loose ground in the switch or power wire
goin fast and draggin da bumper comin to a street neer you !!! been there did it and done it east coast to west coast , up north to the dirty south
BigEd
Post by BigEd »
Blinkers and flashers are seperate switch (not sure about relays) but emergency flashers work. Only other thing in this switch is the wipers and wiper spray button and they work.
PONY GUY
Post by PONY GUY »
sounds like your multifuntion switch is bad to me . they are not to hard ot change either . Did u upgrade the flasher relay to a electrnic on or just on of those silver circle ones ???? If I have to change a flasher relay I replace it with the better electronic relay
BigEd
Post by BigEd »
Upgraded to a newer style relay.
Went out today and tried both the old and the new one and neither one of them would flash.
BigEd
Post by BigEd »
Guess I have to change my Blinker Fluid also!
:rolleyes:
Do-It-To-It
:iagree: :party:
BigEd
Post by BigEd »
Fixed itself! :banghead:
Went out last night with no problems. :confused:
Do-It-To-It
ya see prayin works for some shit :beathorse:
