1995 Mustang Cobra Convert,1 of 1003 made that year, Black with black top. Matching engine block numbers to frame,Street/Strip Car, Ready for track or Street Racer. GREAT CONDITION, 100 miles on MOTOR & TRANS Full interior, Electric Top, New bfg dr on rear,prostars all around w/ new 165s up front, leather seats, car completey wired for nitrous, bottle in trunk, heater, hidden switch panel in ash tray, Full Auto Meter Gauge set, TACH with Light and Memory recall, Boost,/Vac, air Fuel/Ratio, Oil Pressure, water temp, trans temp, nitrous pressure. (Body & SuSpension ) Stock panels, QA1 Tube k Member, Lakewood 90/10's front shocks,cc plates, Stock Rear Suspension,drag launch springs f&r, 8.8 rear with 373's, SubFrame Connectors, Battery in trunk. (MOTOR) 347 FORGED Stroker motor, Cast 95 SVT Block, Scat Forged 4340 Crank, Scat H Beam forged rods, Custom Ross Forged Nitrous Pistons and Rings, all ARP STUDS AND HARDWARE, High Volume Pump. Clevite 77 Race bearings, Custom Cam Motion Roller Camshaft( intake.574 / exhaust.596 ) 112 lobe sep. 237 dur/244 dur @.05. Less than 2 hours of engine running time including break in. FRESH MOTOR!! 10.5:1 compression Trick Flow Stage 2 Track Heat Heads, Trick Flow Track Heat Intake Upper & LOwer Ported) Aeromotive 255 pump, dual 8An fuel feed lines, Areomotivie Billet fuel rails, 6An Return with bypass areomotive regulator, MSD Pro Billet Distributor, 1 7/8 Long Tube Headers, 3 inch collectors, 3 Inch Pro Chamber, 3 Inch Pro Dumps, Redneck performance custom converter 3500 stall speed. Performance Automatic RACE C4 Trans 26 spline case with 7 quart sump, Pro street billet Shifter, Bulletproof bell housing, 8 an Trans Coolent lines, front mount Cooler, No Brake on trans, Fluidyne Dampner,300 race wires. NO AC, NO SMOG, NO EGR. 36 lb Rc Engineering Injectors, Big Pro M Meter, MOTOR RUNS GREAT... SUPER STRONG... MUCH MORE TO LIST.... MUST SEE.and hear. Never been raced with new motor or trans.runs cool,both engine and tranny
pm me with questions.looking for a notch or kick a%@ fairmont box, or 11k/bo
95 cobra vert fs/t
barettabob
95 cobra vert fs/t
barettabob
Re: 95 cobra vert fs/t
on a mustang dyno this motor was 385rwh n/a with a c4 and 3500 stall 2nd gear to 80mph only for a street tune;)
barettabob
offers
