wire gremlin ??
provet
wire gremlin ??
I have a sbc 355 with a 671 bds blower. msd ignition. I changed from carbs. to hilborn fuel injection. followed all intallations with all voltage coming from bat. and all grounds back to bat. I'm having a problem with car just shutting down with no warning, seems to be eletrical because it is like you hit the inginition switch. car seems to run fine,idles ok. but don't know for sure. I havn't put final tune up and adjustment on it yet. been chasing this gremlin! any help would be appreciate. thanks
Do-It-To-It
Re: wire gremlin ??
is the ignition cuttin of i guess or is it runnin out of the fuse box do ya have a lead heavy wire 4gauge or larger runnin from your battery to the nut on the back of the alternator second try to run a wire from battery to a switch in the car then back out to your msd box the ignition wire thin red and if ya have an hei make sure and run the same wire off the switch to that also .the problem could be in your fuse box and if it is the switch shall fix it . hope you can undestand that i suck describin shit on computers
let me know how ya make out if ya still cant figure it il give ya my phone 3 and il walk ya through it
let me know how ya make out if ya still cant figure it il give ya my phone 3 and il walk ya through itgoin fast and draggin da bumper comin to a street neer you !!! been there did it and done it east coast to west coast , up north to the dirty south
Do-It-To-It
Re: wire gremlin ??
make sure ya have a 10gauge wire runnin from your battery to your fender right next to battery ...then make sure your battery is grounded right to your block 4 gauge or 2 gauge then another battery size cable to your frame rail 4 or 2 gauge
provet
Re: wire gremlin ??
problem solved finally. thanks for reply and help.
Do-It-To-It
Re: wire gremlin ??
no problem bro . get that thing out on the street now .
