Ignition timing
catchk9
Ignition timing
Post by catchk9 »
How much timing are you guys running on your bbc-468. I know every motor is different but I am trying to get a baseline tune for the track. How much is too much and too little?
Re: Ignition timing
Post by OLDHEAD »
catchk9 wrote:How much timing are you guys running on your bbc-468. I know every motor is different but I am trying to get a baseline tune for the track. How much is too much and too little?
Stock GM heads like 36-40,Big Chiefs like 28-30,depends on the heads....I don't think you could go wrong with 36.............Oldhead
Re: Ignition timing
Post by Gameracing »
The type of fuel your running will determine timing
Re: Ignition timing
IF IT IS OLD SCHOOL BIG CHAMBER AND BIG DOME YOUR IN A WORLD OF SLOW IN THE LOW 30'S !!
COMPRESSION,FLAME NOTCH ,QUENCH AREA?? YOUR SAFE AT 32 WITH JUST ABOUT ANYTHING BBC AND RUN IT UP 2 DEG EACH PASS. TILL IT SLOWS DOWN AND TAKE OUT 3-4 DEG.
