how to change a speedo gear on a 87 mustang
bhrp
Post by bhrp »
i have a 88 gt 5 sp. 302.. i put 3.73 in the rear and it seems that the speedo runs about 120 at 60 mph.
anywhere i can get the gear and hoe hard is it to put in.
DRIVE IT LIKE YOU STOLE IT.IF THE SHIT BRAKES FIX IT...
rednotch
Re: how to change a speedo gear on a 87 mustang
Post by rednotch »
http://www.ddperformance.com/Speedometer%20Chart.htm find out what gear drive you have in the transmission then order the right driven gear.... takes about 10 mins to change after jacking the car up.... only one 11mm bolt
