What fluid?
s10aromeo
What fluid?
I have a TCI built th350.I am past break in.What fluid should I throw in her?I was told to use type f... and change it often.
s10aromeo
Re: What fluid?
I was checking out TCI MAX Shift and synthetic max shift.Anyone have any comment on them.Are they worth the money.I would rather have clean type f becuase it is cheaper to changed often.Am I loosing cooling running type f over the TCI stuff.I had a little fluid spit out of the breather.Thanks.
gmracing355
Re: What fluid?
I use type f as recommed by b&m after I put on thier deep pan. No problems yet and I go low 11s and drive it alot on the street.
Greg
Greg
Re: What fluid?
I use Redline synthetic "Racing ATF". Transmissions look great when I take them apart after may runs. Most times i put them right back together.
Re: What fluid?
wolfs head has a universal synthetic that is dollar for dollar the best stuff out there !! if it will live in a c/v trans it will live in a race trans .its flash/boil and stability is super !!!
