VIPER car alarm system ?
AndrewMK
Post by AndrewMK »
my truck came with a viper 7701 v/p/x system and i have not bothered with it untill now cause it has a remote starter. I think my remote needs to be re-programed does any one have experience with them. right now nothing works with it and the battery in the remote is fresh, the manual for it is for the newest and vipers tech support is call a dealer. any help would be great. Thanks Andrew.
S&W Swing Arm Dragster
JnJ Customs Paint
380 SBC
FoxBodyAngel
Re: VIPER car alarm system ?
Post by FoxBodyAngel »
Andrew My Mustang has a Viper alarm on it and if you sneeze 40feet away from the car It sets the alarm off...LoL I Swear to you
Good Luck with it cause I'm clueless myself as to how to reset it to be less sensitive!! It was already on the car when I bought it :mad2:
I was just gonna cut it at the fuse box BUT then D2 brought something up that made me think....When my alarm goes off my ignition locks up and the car wont let you start it or even turn the key SO I got nervous!!!
GOOD LUCK and let me know if you figure it out.
AndrewMK
Post by AndrewMK »
yea im clue less too i just wanna use the electric starter function u can by pass the alarm par or some thing who knows..
JnJ Customs Paint
380 SBC
BADAZZ89LX
Post by BADAZZ89LX »
take it to a place that deals/installs alarms and have them program it
FORMERLY 1FASTSUPERCOUPE OF GDR
Bri86SS
Post by Bri86SS »
Andrew, do you know where the "brain box" is? There should be an additional controller box that plugs into the brain to control the auto start. All accesories should be fused. You're should look under the dash and make sure everything is connected and any fuses are good. Also, this truck is automatic trans right?
Daphne, does your Mustang have a proximity sensor? The box is usually mounted somewhere in the center of the interior. Usually it's a clear plastic box, it's not very big either.
AndrewMK
Post by AndrewMK »
yes i seen the clear box and the black brain box the fuse was good it was only a 2amp fuse tho. all the connections look good and clean.
JnJ Customs Paint
380 SBC
Bri86SS
Post by Bri86SS »
Did you test for power? Are there any relays in the circurt from the starter control box into the truck's wiring?
I'm not sure of the color coding of the wiring though. I've never installed these professionally, but I've done a few alarm installs. Trying to throw out some ideas.
BADAZZ89LX
like i said..take it to an install shop and quit being cheap
FoxBodyAngel
Bri86SS wrote:Daphne, does your Mustang have a proximity sensor? The box is usually mounted somewhere in the center of the interior. Usually it's a clear plastic box, it's not very big either.
Sorry I didn't think I was gonna get any kind of Tech help on this..LoL
I will take a look around and check things out!!! It doesn't bother me as much as my neighbors and friends although I would like to be able to put it on silent or valet mode when I'm working on the car. When I do simple things like an oil change/plugs/even wash the car the lightest tap and the alarm starts bugging out. Thunder sets the alarm off...Lmao Like I said I'm use to it
And I'm not being cheap just could really careless if ppl get pissed off Really!! It is what it is and after having My car broken into(yrs back)because of some asshole that robbed someone and it was taken out on Me, The alarm helps me sleep a bit better at night! Plus all the ppl that get annoyed are all the same ppl that didn't hear a thing when my windows were being smashed out.
AndrewMK
Post by AndrewMK »
BADAZZ89LX wrote:like i said..take it to an install shop and quit being cheap
yea im far from cheap. i gotta find some time to get to one.
JnJ Customs Paint
380 SBC
67camaro101
Post by 67camaro101 »
ask mr. Ed Hess i believe he deals with them.
Coming Soon
www.bbphotondesign.com
Supporter of Gonedragracing
Proud supporter of WTF Web Design
ed hess
Post by ed hess »
67camaro101 wrote:ask mr. Ed Hess i believe he deals with them.
yeah I bet he can help you out.
here is his phone number
856-546-8439
tell him i told you to call.
btw dont ask him about the wall. :)
Black1987stang
Post by Black1987stang »
I'm on a family member's computer so I'm not able to quote for some reason but anyway...For MustangAngel there should be a little adjustment on the sensor to change the sensitivity of the alarm, at least on the one I had bought the sensor is attached to a bundle of wires somewhere in the car with a ziptie or something and there was a Min-Max adjustment you can adjust with a screwdriver on the sensor to turn up the sensitivity or down.....
...And for MustangAngel and Andrew most alarms (at least in the cars I seen anyway) there is a mini toggle on/off switch that disables the alarm system. My mom has hers down by where some cars have the hood release on the left hand side down by the feet but they can be anywhere, hidden or whatever....or maybe have none at all. And if it just started not working after you changed the battery then yeah should just need to be reprogrammed since you reset it by taking the old battery out, which if it's like for some remote starters it's easy you just keep pressing a button till it finds the correct code? or you hold down certain buttons until you hear the relays click or something like that. Shouldn't be that hard to find though, you can find anything online.
306 machined/built n tuned by me..heads/cam/intake/gears/tremec etc.4 SALE..World Products heads..Solid Roller Lifter.10/10 351W crank and rods, bearings w/ Domed Forged TRW pistons pressed on them..Bunch of GM 350 parts
lownslow1988
Post by lownslow1988 »
i used to install these...just put it in valet mode....this will disable the alarm from arming but the remote start will still work properly...you said you have the manual so just read up on the sequence...im pretty sure its key on then off and press the button under dash once and let go...then the alarm led will come on solid....it will stay on while in valet mode....you can PM me if you need help as ill probably forget about this thread
