water in oil?
91vert
water in oil?
hey guys a i got a 302 with windsor jr heads. i changed the oil and it had a little white spots on the dipstick. so i poped the valve cover off and there was small spot of water in the oil could this be caused be mositure or doe i have a blow head gaskets. i dont wanna rip apart the whole top end to find out it was something stupid so how do i check to find out wat it is?
10secTim
Re: water in oil?
91vert wrote:hey guys a i got a 302 with windsor jr heads. i changed the oil and it had a little white spots on the dipstick. so i poped the valve cover off and there was small spot of water in the oil could this be caused be mositure or doe i have a blow head gaskets. i dont wanna rip apart the whole top end to find out it was something stupid so how do i check to find out wat it is?
put a radiator pres. tester on the rad. pump it up to the recomended presure and watch the gauge to see if it drops and how fast. you should not see a quick drop off.
CT408
Re: water in oil?
You could do a compression test or leak down test before you tear it down also to look for weak cylinders.
If your in CT and need to borrow a Radiator Pressure tester, let me know. I have one you can borrow. I'm in Meriden.
- mytmouz
Re: water in oil?
If it is not mixed with the oil, just clear it's probably condensation...
Chevy made the LUV before they made the S10, so 'Who's your Daddy?'
Groundupperformance
Re: water in oil?
pcv system working?
91vert
Re: water in oil?
i took the evac kit off when i changed my headers bc the long tubes did not have the peice to attach my pvc system back up. could that be the cause of this?
Groundupperformance
Re: water in oil?
yes.
91vert
Re: water in oil?
so if i hook this up and if the problem does not go away wat should be next to check?intake gasket?
