ford soleniod on gm
- trailblizzer
ford soleniod on gm
hey guys ive done this before but it was about 3 years ago anyone know how to wire the ford starter soleniod up to work on the gm so u can mount it to the firewall any helps wud be great thanks
87fordgt
Re: ford soleniod on gm
you have to jump the big post to the little post on the gm starter
then run a hot wire from the for sel. to the big post of the starter
take the stock wires hook them to the hot side of the for sel. and one of the little posts
Don't forget the ford selnoid must be grounded.....There are 2 small terms on the ford selnoid,if the one does not work use the other...Oldhead
- trailblizzer
all i have as far as the stock wiring is the purple wire nothing else so where wud that go i no the jumping wire part and obviosly bat to ford sel then sel to gm starter but where does purple go cuz theres 2 samll posts
- mytmouz
To the s terminal on the solenoid...
Chevy made the LUV before they made the S10, so 'Who's your Daddy?'
