Hei question
shitty67
Hei question
I just changed my distributor in my 71 c10 from points to the Hei, I was wondering what should I gap the plugs at and what timing degree should I set it at. I did put a Msd 6a box in it too. The truck is bone stock with only 58,000 miles on the 307 so its not a hot rod what so ever. Thanks Mark.
Re: Hei question
with no vacuum advance hooked up you should set full advance to 32 deg. then ck your base time at idle ad see if your above 15 .
the 12v feed needs to be cut and taped off or trigger a relay to feed alt/battery voltage to the big feed on the hei .most points had a resistor wire and a crank volt only feed ya cant use either our your hei will die above 2800 or hard start/stall .
