key wont start
Posted: Sat May 10, 2008 2:06 pm
by BIGWOOD
having problems... im sure its an easy fix but i cant figure it out... got the motor to fire up by jumping the celnoid...but cant get the key to turn it over... it was a 4cyl automatic car that i converted to stick and 8cyl carburated ...is it the wires that plug into the pedal assembly? could that be wrong? is there a wire somewhere that isnt hooked up? please pm me... thanks!!!
oh the car is a 93 notch
Re: key wont start
Posted: Sat May 10, 2008 6:15 pm
by 67camaro101
make sure when you turn the key as if you were going to start it you have a hot wire going to the cylinoid. also if its equipped with a neutral safety switch check that.
Re: key wont start
Posted: Sat May 10, 2008 10:34 pm
by rednotch
5 spd yoiu need the red. blue stripped wire plugged in to the clutch pedal.
if its an auto you need to make a jupper wire that for the harness... you can also do that if you want to bypass using the clutch...
since it was an auto the factory harness from the car should have that jumper wire in it all ready.. its ussualy still taped the the main harness on autos so you have to dig for it.
